bavinck
- Feb 12, 2014
email sent
email sent
Darin,
Any idea how to apply sonarworks and ooyh from a multichannel video file in jriver? Sounds like only 2 channel audio is coming out of sonarworks/jriver into ooyh. Any idea on a fix?
Darin,
So, I've experimented with upmixing but the only choice was JRiver's upmixing feature, which is very poor quality: artificial, phasey, and cloudy. The problem was always that no music host, as far as I'm aware, can handle multichannel plugins.
With foobar2000 you can use multichannel VST plugins.
As both an Sonarworks and an OOYH user, I can use both only with two channel applications by running Sonarworks as a JRiver Plugin and sending the output to OOYH.
As a result, when I'm doing multi channel movies, I find I strongly prefer to use my LCD X's to my Senn HD 800's. I find that the soundstaging with the X's in multichannel Dolby HD is just fine, and its bass makes it more realistic for movies. I could probably enjoy the Senns if I had multichannel eq since eq does wonders for the bass in 2 channel, but without that I find the bass lacking for home theatre, also the unequalized highs prove wearing even with my SD mod.
Darin, i wonder if I could get your thoughts on something.
The drawback of OOYH is that there is no simple way to customize the presets for each individual user. I'm wondering if repositioning the headphone drivers would help augment the difference between the measured file and the user.
Lately, I've been experimenting with this. Normally, of course, the earcups simply lay flat against my head around my ears. However, I added some foam shapes to the top of the earcups which allows me to articulate the angle and position of the drivers relative to my ear. As I've done this, I've found a placement that dramatically increases the accuracy and realism of the convolution processing. It's actually pretty amazing to me.
I'm wondering if the improvements are because, in so doing, I'm more closely approximating the measured HRTF and maybe even altering the pinnae response. It's given me an idea of just how much better a custom measurement would be. At the same time, the results sound so "correct" at this point, I'm not sure how much more accurate it can get. Of at truth, I'm not sure exactly what's going on, but this repositioning, along with fine tuning the upmixing stereo to surround, has given me another jump in sound.
