PlantsmanTX
They got 5 purchases, so it's $70 now. I think I'll rewatch Cleg's review.These are now up on Massdrop for $80.
Wonder how these stack up to the iBasso IT01, which seems to be the current <$100 king.
Yes, you'll be able to get plentiful enough of volume.Can they be driven by a (iPhone 6s) mobile phone ?
Default tip.For anyone who owns and listens to the kc09, just curious as to what your preferred ear-tip is and why?
Were the default tips you got the ones with the built in filter or the medium bore, non-filter silicone ones?Default tip.
The sound signature reminds me a bit of my SE846. With good seal, the low freqs hit pretty hard while maintaining good resolution, definitely not loose bass. Mid is forward and just a tad on the warm side to lush out vocal. High has tiny bit more air and clarity than EDC to give vocals that nice spark.
I prefer the KC09 over EDC. For $70, IMO, it's a bargain. Impressive what we can get these days for under $100.
I am curious and want to try out EDC3 vs HEM6.
I use Acoustune AET07 S size eartips. KC09 already has its own reverberation generated through the nozzle, and felt like Spiral Dots exaggerate the reverberation a bit too much. Compared to JVC Spiral Dots AET07 sounds more raw(or original), slightly brighter, and more straight-forward.For anyone who owns and listens to the kc09, just curious as to what your preferred ear-tip is and why?
Do you know if there is any difference between the S and M sizes of the AET07 tips regarding their sound? or is it strictly their size?I use Acoustune AET07 S size eartips. KC09 already has its own reverberation generated through the nozzle, and felt like Spiral Dots exaggerate the reverberation a bit too much. Compared to JVC Spiral Dots AET07 sounds more raw(or original), slightly brighter, and more straight-forward.
It's strictly about the size. The M size feels slightly larger than other normal M sized eartips, that's why I'm using S for AET07 while using M for Spiral Dots.Do you know if there is any difference between the S and M sizes of the AET07 tips regarding their sound? or is it strictly their size?
You know of a site that regularly sells them? Could only find one and they charge more for shipping than the actual tips.It's strictly about the size. The M size feels slightly larger than other normal M sized eartips, that's why I'm using S for AET07 while using M for Spiral Dots.
KC09's nozzle length is more on the longer side than other iems, so S should more likely fit you if you're using M for other eartips.
I got mine directly from South Korea and Japan, so not sure about the websites. (Though 3 pairs should cost around $10)You know of a site that regularly sells them? Could only find one and they charge more for shipping than the actual tips.
