khbaur330162
Vintage Ortho Ninja 🥷
- Aug 5, 2006
Let us know how it goes. CAD MH320 is 45mm, HP-2 is 46mm. If you have a dremel with a little cutoff wheel you can shave the front of the driver retention "lip" and then the driver lays flat on the baffle. It's an easy driver install, imho, but my HP-50A sounded too dark with stock pads, I swapped for velour, much better sound.Just ordered a Yamaha HP-2 on a whim (also a Denon HP-2 out of pure curiosity). Looking forward to hearing them, should be fifty bucks well spent.
Got some more sheepskin flat pads, so finally swapped out the angled pads on U70's.
YHD sounds a little weird due to 300Hz-1kHz information, but after you get used to it I think it's clearer and just better than U70. Bass is nice on both, hard to choose, but maybe I pick YHD actually. Can't wait for the hybrid pads, hopefully it does wonders for YHD's.
