ruhenheiM
- Dec 27, 2010
there is wharfedale isodynamic available on some online auction site but the guy who sell it won't do international shipping
Gah,
Can anyone see anything potentially wrong?
There's a trick you can try to avoid overtightening the screws and stripping the threads.
But you need to use a ratcheting screwdriver.
Turn the ratcheting mechanism to the opposite direction and tighten them down until it starts to give and begins to spin, then you know you are close ( have a look ).
This usually happens right at the point where the screwhead bottoms out at the baffle top.
It's usually a careful small finger tighten after that.
I find this works on most things, but if the screwholes are a bit snug right away it might start skipping and not work this way.
Had to resort to that on the Fostex T50rp's after opening ~100 times ( no joke ) but after that point doing the reverse ratchet method worked perfectly for another 20+ openings
BMF successfully redid screwthreads with superglue I think.
I may or may not have done that also i forget.
Might have used a plastic melting solution dropped into a hole then tiny drill bit to give just enough of a hole for the screws to rebite.
That info is buried on the first post at the T50RP Incremental Mods thread.
Sorry to hear hope this works out for you.
Oh, you're the dude that bought that pair. I have no clue as to how to repair a sheared strut. Honestly, it's probably smarter to gut the original housing and put the driver somewhere better. I'd want to put it into a Teac hp-100 perhapsAnyone interested in a YH-100? The left earcup broke off from the pivot, but both sides function perfectly (which I bought that way).
