Any particular reason? Besides the driver flex I find the original shells to be great-fitting. I'd be afraid reshelling will alter the sound.Do you guys know any brand that can reshell the Oriolus to make it a CIEM?
Oriolus Hybrid IEM
- Thread starter rookie2009
- Tags
- ibasso
alphanumerix1
http://www.jaben.com.hk/?product=oriolus-2
jaben Oriolus actually offers this service. in Hong Kong you can upgrade to ciem for 1500hkd
Very cool
- Jan 12, 2014
Mine just cracked on the left piece while I'm inserting a different cable. So I thought I could send it somewhere to make them custom.Any particular reason? Besides the driver flex I find the original shells to be great-fitting. I'd be afraid reshelling will alter the sound.
1TrickPony
Guy. I feel for you. Its like your top pick iem! Hopefully it works out on your endMine just cracked on the left piece while I'm inserting a different cable. So I thought I could send it somewhere to make them custom.
gunwale
- Dec 28, 2016
maybe you can try this https://nocaudio.com/order/ciem/ not sure if they have international shipping.
corn
- Jun 19, 2012
A little help needed. The 2 pin connector is loose. Any idea on how to fix that?
gunwale
- Dec 28, 2016
which aftermarket cable are you using? i was told at a local shop that the oriolus 2 pin port has quality control issues where some of them are shallower than others.
corn
- Jun 19, 2012
Currently using the Linum cable.
Oh man! Didn't expect that answer. Good luck in reshelling. The Oriolus is truly a keeper.Mine just cracked on the left piece while I'm inserting a different cable. So I thought I could send it somewhere to make them custom.
all999
So I got my MK2 five days ago. Burning in, tip rolling and fighting with a stock cable. I found out that the only tips that works for me Ina long term are foams. I have a bunch of different tips, silicones and foams and the best results I get is with black, unknown foam tips shown on pics. Could You guys help me to spot what exactly foams are these? My guess is crystal tips but Im not sure. They are soft and have a little sticky outer surface.
On another note, a cable provided with a Chinese revision is really bad ergonomically. If they didn't provide a shirt clip, I couldn't really use it.
Soundwise these are superb. Waiting for my balanced FAW hybrid for Sony WM1A.
Thanks!
Thanks!
1TrickPony
Penon Audio. 99c foams does the job for me. I also suggest a treasure hunt for Monster Turbine triple flanges. Subbass hits HARD and deep lol. Plus added clean separation.
These foams though add live coherent feel to the sound though
all999
Just checked them and I think these may be the ones I'm looking for
There are some different bore sizes, 4,5 or 4,9mm?
1TrickPony
4.9mm all the way. Slides right in. Easy peasy.Just checked them and I think these may be the ones I'm looking for
Might be worth giving the MandrinEs Symbio W a go if you haven't already, you get the best of both silicone/foam worlds and they work a treat. They've been a revelation with the MK2s for me.
all999
I have them and tried already. Short nozzle and large shells makes every silicone tips I have tried unusable in my shallow conchas. They make some kind of resonance chamber. And I'm getting all movement, cable microphonics and even my spine cracks like amped Symbios aren't any better. Foam tips works great for me, but almost all of them degrades SQ. Ordered Crystal Tips and those from Penon. I'm pretty sure new FAW cable will improve ergonomics and decrease microphonics.
Thanks for your tip
