Oriolus Hybrid IEM
- Thread starter rookie2009
- Tags
- ibasso
Telacap99
- Mar 7, 2016
- Messages
- 117
- Reaction score
- 28
Oic the iems themeselves look like that but the cable isn't, with gold connector at the iem side and L shaped 3.5mm single ended plug at dap side.
Kerouac
Maybe it was a special upgrade cable in that pic...wouldn't know
Got the pic from this (earlier) post: http://www.head-fi.org/t/739745/ibasso-oriolus-hybrid-iem/120#post_12186742
Uncle E1
Member of the Trade: E1 Personal Audio
- May 10, 2015
- Messages
- 408
- Reaction score
- 81
the set in the picture is solely for the Japanese market only
sdwong
- Mar 26, 2016
- Messages
- 77
- Reaction score
- 19
Demo and bought it straight. However, it's out of stock at the moment and I am number 6 in the queue. The stock tip is too short for me. Fitted well and this IEM sounds great. I chose this instead of the Jupiter and Angie II. Everything sound so natural. I have been listening to my ES5 for 4 years and finally succeeded in looking for a universal fit IEM that I like.
What are some recommend tips? Shop recommend Spinfit which they claim is longer.
Kerouac
How would you compare Oriolus' sq and signature vs that of SE5?
I have JVC spiral dot (M) tips on almost all my universals and these work great for me
Don't know if they're longer than your stock tips though, but maybe you can try them...
Btw, welcome to HF (saw the above was your first post)!
proedros
I have JVC spiral dot (M) tips on almost all my universals and these work great for me![]()
it's not the SE5 (spiral ears) he mentioned but the ES5 (westone)
Sonic Ecstasy
- May 1, 2013
- Messages
- 110
- Reaction score
- 28
Are there any comparisons with fitear tg! 334?
Sonic Ecstasy
- May 1, 2013
- Messages
- 110
- Reaction score
- 28
Where did you buy yours from?
Uncle E1
- May 10, 2015
- Messages
- 408
- Reaction score
- 81
the bass is better controlled (flabby on the tg334) and the highs are well extended
jmills8
Previously known as bmiamihk
Flabby bass means it has a lot of bass? What sort of music you listen to ?the bass is better controlled (flabby on the tg334) and the highs are well extended
Uncle E1
- May 10, 2015
- Messages
- 408
- Reaction score
- 81
the bass decay on the tg334 can be overwhelming where the oriolus tightens it.
Sonic Ecstasy
- May 1, 2013
- Messages
- 110
- Reaction score
- 28
How would you compare the instrument separation, clarity and imaging of the Oriolus to the tg! 334?
avesta07
- Apr 15, 2013
- Messages
- 38
- Reaction score
- 10
following this discussion, as i saw oriolus in the local shop and they said its on par with the TG334.
also wondering how it compare with other universal, such as Inear SD4, Tralucent 1Plus2, Shure 846 and Earsonic S-EM6.
zeissiez
- Mar 13, 2014
- Messages
- 437
- Reaction score
- 156
Haven't heard the others, but the Oriolus was way better than 846 and S-EM6, in soundstage width and depth, clarity, and top to bottom coherency.
