dammit I got caught lolhahaha
OPUS#3 Hi-Res Audio player w/wifi and streaming
- Thread starter Bengkia369
haha i know where you're coming from.
- Oct 6, 2013
lol luckily, Jupiter does not hiss on it!
But yeah, my recent opus 1 was real bad. Audio-opus support did not even know what went wrong with song cannot be played.
Now I'm missing a leather case. But at least Opus #3 works and everything seems functional.
Opus#3 should come with a case, a genuine $50-60 Dignis leather case. As it was pointed out before #3 edges are sharp, needs a case. Who was your seller? If it's MusicTeck, Andrew will take care of you right away. If it's some other seller, return it back and deal only with MT who is authorized Opus seller.
I shouldve chose musictek :cOpus#3 should come with a case, a genuine $50-60 Dignis leather case. As it was pointed out before #3 edges are sharp, needs a case. Who was your seller? If it's MusicTeck, Andrew will take care of you right away. If it's some other seller, return it back and deal only with MT who is authorized Opus seller.
It was prostudio.
It didnt come with shrink wrap. But I dont see why they would take it out of the box and sell it :c
- Oct 6, 2013
It was prostudio.
Unless if it's a returned unit?
Could be that is case. Well I better return it for real. I notice sharp edges on corners too.Unless if it's a returned unit?
even if you get another unit - the edges will always be that sharp.
but it will have a case at leasteven if you get another unit - the edges will always be that sharp.
haha case woes...
Dobrescu George
Reviewer: AudiophileHeaven
I'm actually using it without the case and I couldn't mind the edges less - I actually like the design.
At any rate though, if it was opened, maybe you'd want to return, just for your peace of mind.
Still one of the best DAPs out there to those ears
Dont worry dob. Im going to get another opus 3. But from musictek this time.I'm actually using it without the case and I couldn't mind the edges less - I actually like the design.
Sad mine had to go. But I think its best to get it from an authorized the bit dealer now lol.
I cant trust someone who sells a New product. And shrink wrap did not exist and no leather case inside. Who knows what else im missing in that box
Dazzert318
- Mar 3, 2016
I can highly recommend Musicteck. I've purchased both the Opus #2 and #3 directly from them and Andrew could not have been more helpful on both occasions. Opus #3 was supplied with the leather case as part of the package.
specKtre
- Dec 28, 2015
specKtre
- Dec 28, 2015
- Oct 14, 2013
Musictek is authorized dealer and Andrew is awesome to deal with
