Hyjacked
- Jun 29, 2014
Hi,
Currently I am running a pair of HE-500s off a Schiit Magni/Modi combo. Yes, I know a higher end DAC and amp would certainly increase sound quality, but for now, they will have to do. I already plan to upgrade to something along the lines of the Lyr 2 and Bitfrost. The other thing I am aware I need to upgrade is the cable because currently I am using the stock cable which I know is inferior in comparison to others. I am not sure what cable to upgrade to, however. I do not believe my audio source is bad, but I could be wrong. Right now I use Spotify and have the 320kbps high definition streaming option enabled. I know there are properties for the Schiit Modi in Windows, but I don't know if there is anything that I should be changing. I did notice that the default "sample rate and bit depth" are on the lowest, however, I am not sure if I am able to support changing it. I know a couple of mods for the HE-500 exist that I was planning on looking into, but if you would like to list some, by all means go ahead. I have also swapped the leather pads for the velour, as I noticed that make the headphones sound more airy. Thanks for taking the time to read my post.
