Oppo PM-3 : The Portable Planar - Impressions
340 341 342 343 344 345 346 347 348 349
351 352 353 354 355 356 357 358 359 360
  1. Jim Bobber
    Hey Guys,
    Thinking of getting the fiio x7 mm ii which has a 2.5mm balanced trrs output, does anyone know what I need on the other end for the pm-3's? 3.5mm of course, but I see there are a few versions, trs, trrs and trrrs? I'm a little confused :)
    Cheers
  2. JML
    You need 3.5mm TRRS at the headphones. (I believe the only TRRRS is the 4.4mm JEITA/SONY.) But you need to get one that will fit in the recess on the earpiece. Here's my Double Helix 3.5mm to 4.4mm balanced cable (for a Sony WM-1A), with Eidolic connectors:
    [​IMG]
    alphanumerix1 likes this.
  3. Jim Bobber
    Awesome, thank you!!
  4. Paul Oorbeek
    Will an Ifi Nano IDSD together with LG-V20 smartphone be an good match or is an Ibasso IB14 Bushmaster an better option?
  5. FastAndClean
    i pulled the trigger, my first planars, i hope they are good
  6. x_lk
    http://www.ebay.ca/itm/New-Dyson-Au...-X1-Balanced-Headphone-Cable-2M-/112439509614
    http://www.ebay.ca/itm/New-Dyson-Au...-X1-Balanced-Headphone-Cable-2M-/112468989539
    This costs less, but not as flexible:
    http://www.ebay.com/itm/New-Dyson-A...alanced-Headphone-Cable-2-Meter-/112279417341
    Do ask for the 2.5mm trrs option. Seller claims no additional charge.
  7. FastAndClean
    can they take sub bass boost without problems with control in the low end?
  8. FastAndClean
  9. chillaxing
    I use to boost the crap (+20db) out of these things and they took it like a champ.
    FastAndClean likes this.
  10. FastAndClean
    they are so small lol
  11. Sonic Defender Contributor
    I loved the PM3 when I owned them. At the end I had a custom balanced cable made so that I could use them balanced with the Onkyo DP-X1 and the results were very good indeed. Then I decided to go Bluetooth for portable audio anyway so sold the Onkyo and PM3.
  12. FastAndClean
    i will not sell them, they are special for sure, what a build quality to
  13. FastAndClean
    the bass is tight and fast, mids forward, treble a little bit subdued after 10khz, isolation is great, the driver is very well damped maybe a little to much
  14. JamesAnthony
    I know this might sound a bit stupid but does anyone find them a touch compressed sounding? I have used them for a while now and have both a forzaaudio custom cable and a forzaaudio balanced 2,5mm (for some reason I reckon the unbalanced sounds better). It might just be my ears but some days I love them some days I think they sound very dampened. I am using an AK70. Any suggestions? Take off some of the padding? I really dont know.
  15. FastAndClean
    yes, they are a little bit overdamped
