OPPO PM-3 Portable Planar Magnetic Headphones Loaner Program
Apr 30, 2015 at 10:48 PM Post #151 of 991
I would like to participate in the PM-3 Loaner program, and agree to the terms and conditions. I'm just getting into my HE-560's and am interested in a more portable set up as I am on the road lots.
May 2, 2015 at 1:07 AM Post #153 of 991
PM-3 Unit #2 is safely in my care. Everything's there and in good working order. Looking forward to my week with these :L3000:
Looking forward to your impressions
May 2, 2015 at 2:51 AM Post #154 of 991
Have an awesome time! At some point, have a listen to something recorded in a church or other "acoustic location rather than a typical studio, you'll be impressed at the depth the PM-3 can convey!
May 2, 2015 at 3:05 AM Post #155 of 991
Have you tried the PM-2 yet?  Bigger pads, smoother/warmer sound... I found that I preferred them in almost every way to the similar LCD-2f.  Just curious what your thoughts are if you have.
If not, you might try jumping on to the PM-2 loaner program!
just a fyi side note. I believe the PM-2 earpads (~15mm for the PM-1) are actually not as deep compared to the PM-3 earpads (~17mm).
http://www.head-fi.org/t/653032/size-matters-earpad-hole-measurements-for-over-ear-headphones/15
May 2, 2015 at 4:10 AM Post #156 of 991
From memory, I'd probably agree.  I was talking more about circumference, tho.  I find the PM-3 to be about as small as I can go comfortably.  The PM-2 feel much bigger around the ears.
May 2, 2015 at 10:26 AM Post #157 of 991
Thanks for the tip. I'll try some live classical recordings with these.
May 2, 2015 at 10:28 AM Post #158 of 991
Yeah, I've got small ears and PM-3 fit really well. I can see people with large ears feeling crowded with these.
May 2, 2015 at 10:49 AM Post #160 of 991
Does anyone have a measurement on the internal height of the PM-3 cups?
Height including padding is ~9.5cm
Earspace height inside the cup is ~5.7cm
Width including padding is ~7.5cm
Earspace width inside the cup is ~3.5cm
Depth is ~2cm.
The pads have a little give in width but much in height.
May 2, 2015 at 2:24 PM Post #161 of 991
These were the official release specs: http://www.head-fi.org/t/653032/size-matters-earpad-hole-measurements-for-over-ear-headphones/30#post_11317874
@nmatheis, if you like to post your own measurements to the thread I linked, I think it could be a helpful resource. thanks! cheers
May 3, 2015 at 7:42 AM Post #162 of 991
Received the loaners yesterday. First tried them straight out of the iPhone. Very, nice. Later tried them with iPad/Dragonfly/Tidal. Even a neighbor cutting his lawn it was great listening on the deck. I haven't gushed about a pair of headphones in a while. I really, like these. Fantastic build and comfort. Have to do some more listening.
May 4, 2015 at 1:24 PM Post #163 of 991
FYI
The address I gave Oppo will be changing. I dont have a new address yet. Whoever is mailing to me, please check with me before sending anything. I have also PM'd Oppo. Sorry for the inconvenience.
