OPPO PM-3 + HA-2 vs OPPO PM-2 - Best choice for at home portable?
Nov 14, 2015 at 12:53 PM Thread Starter Post #1 of 10
gbx2006
As the title suggests, I am debating between getting the OPPO PM-3 + HA-2 or the OPPO PM-2. Either way I go the price is about $700. The headphones will be used primarily at home and my sources are either a Samsung Galaxy S6 or a Windows PC. In terms of sound quality, which would be the best way to go? I am hoping there are some people on here that have heard both setups and could steer me in the right direction.
Thanks!
Nov 14, 2015 at 5:15 PM Post #2 of 10
HUM24H
Curious, what would you be using with the OPPO PM-2?
Nov 14, 2015 at 5:45 PM Post #4 of 10
HUM24H
Fair enough, I would more than likely so go for the OPPO PM-3 + HA-2. This in my opinion give a much better listening experience then plugging the OPPO PM-2 directly into the S6 or PC.
Nov 14, 2015 at 8:12 PM Post #6 of 10
HUM24H
No problem :)
I have the HA-2 with a Note 4 & Fidue A83, it sounds fantastic! You will love it!
Nov 23, 2015 at 4:09 PM Post #7 of 10
MR GARV
Thanks!
Have you already made your purchase yet?
