Psychonaut71
Not heard of the Aeon but will have a look, cheers.Also take a look at the Aeons, $799. Can't speak to the combination with the Mojo, but check the Aeon thread.
Have kind of held back on AKG because of the reports of that sibilance issue - I suppose it comes down to personal preference - some might hear shrill notes others might hear highly defined treble.I find that my AKG 712Pros are the perfect companion to my Oppo PM-1s. Both are excellent, and yet different sounding. The 712Pros can be agressive and exciting, in a good way.
Research I've done so far would indicate that the Beyer house sound might be what I'm after. Have you been able to listen to the DT1990 Pro, and any observations in relation to the 880 and HD800. The prospect of a more 'user friendly' HD800 sounds perfect.As a compliment to the PM-1, consider the affordable Beyerdynamic DT880 600-Ohm version, if you have an amp with enough power, you can stick with the factory, single-ended cabling. But if that power is available from your amp, only via a 4-pin balanced connector (as with the HA-1), take the plunge and get the DT880 600 recabled for balanced operation.
I consider it to be a poor man's HD800, but I actually prefer the DT880-600 over the HD800, in many ways - mostly in terms of bass energy (which is not at all excessive, just much better than the HD800), but also in terms of dynamics. It's very fast, with lots of detail and the treble isn't nearly as finicky, in terms of DAC and amp selection, as that of the HD800. G
et the Beyer factory "Pleather" pads, too, instead of the velour - for a better seal.
See this thread: https://www.head-fi.org/threads/omg-tons-of-bass-from-dt880-05-heres-how.208648/
I have found my Sennheiser HD-800's (with SR Mod) to be a wonderful complement to my Audio Zeniths (modded Oppo PM-1). I listen to both through the Chord Mojo and Chord DAVE, and they both match well to the detail and dynamics of the Chord DACs.
HD-800's go for $700-800 used, with another $20 or so for the SR mod (and 5 minutes to install). One of the best bargains to be had in this hobby of ours (IMO)
I'm trying to get to the bottom as to whether the PM-1 and PM-2 do indeed sound identical if you put the PM-1 pads on the PM-2. As I understand it, the drivers are the same but the housing material and damping are different? Wouldn't the damping change the sound?
Has anyone A/B tested the two recently?
There's quite a big price difference between the two - to the tune of £500. Cosmetics really don't matter to me. I don't understand the justification for pricing the PM-1 at £500 extra on this alone.
The only difference is the PM-1 cpmes with the extra luxury stuff I.e. the wooden case, extra pads, and nicer materials. Sonically they're the same.
