Oppo HA-1 Impressions Thread
Discussion in 'Headphone Amps (full-size)' started by aamefford, May 7, 2014.
337 338 339 340 341 342 343 344 345 346
348 349 350 351 352
  1. avraham
    No experience with the Questyle but I have owned a HA-1 almost from when it was first released. I use it with mainly with HD700 and Oppo PM-1 (tried the HD800s but the higher frequencies did not work for me, it was the headphone because I also have a Benchmark DAC3 HGC and got the same results) with I feel are great results. The HA-1 is built like a tank and is a bargain at the retail price. With any of my headphones (Senns, Beyerdynamic, B&Ws, Oppos) I find no big difference between the HA-1 and the Benchmark.
    bbfoto likes this.
  2. zilch0md
    I would say the HA-1 is much better suited to the LCD-3 than the HD 800 or HD 800S. The Senn HD 800 and HD 800S are about the only headphones that aren't a good match with it, but they are finicky with a lot of amps.
    Audiofiend1 and bbfoto like this.
  3. bbfoto
    I somewhat agree with this. Just "somewhat" because I don't think it's really the amp pairing per se. The HA-1 is a fantastically clear, powerful, and resolving HP amp for any set of cans. But for cans such as the Senns, I think it is more of a bad DAC pairing. If you try another high-quality DAC type paired with the HA-1's HP amp (perhaps a Burr-Brown, AKM, Chord FPGA, etc.), you will most likely find audio bliss with the Senns.
    While not quite as feature-rich or as versatile as the HA-1, I actually preferred my 2015 Audio-gd NFB-28 in regards to SQ. And yes it was also an ESS Sabre DAC.
  4. LarryMagoo
    FWIW....I love my HA-1...but do not use it's Delta Sigma DAC....I have the 800S and to sound it's best, it needs a real Amp not a portable....I am also bummed to read about Oppo's demise.
    The Portable DAP will play the 800S but you will not hear all they can do. I really love all that the HA-1 can do....but it just makes better Music with an R2R type DAC instead of the DS DAC . I use a Schiit Yggdrasil for my HP and Speaker DAC.
    Liu Junyuan likes this.
  5. Audiofiend1
    Can anyone comment on what the Chord Hugo 1 is like paired with the HA1? How would i connect the Hugo to the HA1 and would i still be able to use the XLR balanced output for my headphones?
  6. makan
    You can use the rca out from Hugo to the ha-1 and then use your xlr headphones from the ha-1. I had the Hugo 2 for a couple of weeks and found the Hugo 2 paired well with the ha-1
  7. Audiofiend1
    So i can use the headphones but i take it that it just won't be a balanced output/setup because of the rca cables? So there's not really any benefit to using an xlr over se cable in this case?
  8. makan
    The benefit you will get is extra wattage out of the xlr4 headphone output into your headphones. Some people can hear a difference between the xlr4 output vs SE in the headphones. Certainly will be louder for the same volume setting on the HA-1. You just won't have a balanced input.
    Audiofiend1 likes this.
  9. WildStyle-R11
    Seems like most people don't use the actual DAC in the HA-1...Once I get my setup sorted, I will try and use my Marantz SA 8005 DAC. Maybe people are on to something with this. ^^
  10. makan
    FWIW, I use the DAC full time and also to feed my Stax rig. I had Schiit multibit bifrost and gungnir long term to compare and did not feel there was a significant difference. I also have the delta sigma gungnir. I probably do not have golden ears. I don’t hear the digital sheen that some hear from the Ha-1 Dac.
  11. MRC001
    Ditto here. I use my HA-1 as a DAC, headphone amp, and preamp. I love its clean, neutral sound. As an audiophile for 30 years, I've used a lot of different equipment over the years, and I've heard worse than the HA-1 but I've not heard better.
  12. WildStyle-R11
    Well I just want to check for myself. Since I happen to have quite capable, comparable DAC in my setup, as far as I know.
  13. makan
    Nothing like trying it out for a few weeks to see what you hear. Enjoy!
  14. zilch0md
    That's impressive. Which input(s) are you using for the HA-1 DAC?
    Again, this is nice to hear, but which inputs are you using?
    Thanks guys!
348 349 350 351 352
