My Rightmark 6 software is not starting correctly anymore on my win 10
, got to find a solution !
So I have no solid conclusion, but the spectrogram software works fine in win 10. Atleast this is up for discussion.
Here are some pics with and without Intona. My setup: Measuring comp - normal 40 dollar shielded USB cable - WITH/WITHOUT INTONA - HA-1 - PRE-out - Nordost Heimdall XLR - Tascam UH-7000 - Same type USB cable - Measuring computer.
These spectrograms were snapshot'ed with a 40 minute warm HA-1, the volume knob at 3/4'th up = my hegel DAC volume, also Rightmark told me to use this setting when Rightmark worked:
The blue line is the actual measure, the red is the average top, 10 seconds delayed.
The artifacts you see after the tone itself is coming from HA-1, as my Hegel HD25 dac has different artifacts(less in fact) and 20khz buildup.
Noise floor:
Sending a Sin tone 20 hz to the HA-1 DAC:
100 HZ SIN tone to HA-1:
8khz SIN tone sent to HA-1 DAC:
I also found whats happening with my volume knob!! too bad I deleted those spectrograms as I thought initially it was my measuring unit that was cold, but it wasnt, it was once I moved volume knob, the bad bad spectrograms with alot alot of noise disappeared! If I see the volume knob issue again Ill record those spectrograms too.
Taking a snapshot is one thing, but seeing the spectrogram running in the quickest mode, it seems like once Intona device is plugged in, the buildup of the tone on both sides are more calm than without the Intona. Especially through mid-range.
Warm cold unit?
Here is the 8khz tone again cold/warm. Look specifically where the 8khz tone builds up at cold.. its very inaccurate. thats why you have to let the HA-1 unit warm up.
I am not concluding anything in this post. just showing you guys this as I wanted it up for discussion.
Also I modified my Tascam UH-7000 as it has some noise in 21khz++, and I managed to more or less remove it.
You can read about that on my blog if it interests you:
http://heavycorner.com/tascam-uh-7000-fixing-issue-noise/
