So I played around with comparing the HA-1 yesterday and the tldr version is the usual: "Your headphones will make a bigger difference than most anything else". I focused on trying to do an A/B comparison between two amps based on a short portion of a song.
Amps
* Oppo HA-1
* Matrix m-stage from 2011 modified for dual 627 opamps
Source and gear
* Source files:
Sand (Acoustic Version) by Ottmar Liebert (88.2/24) and
Beat It by Michael Jackson (176/24)
* Software: Windows 8.1 and JRiver Media Center 19
* DAC: Mytek 8x192
* Monitor controller: Dangerous Music Monitor ST
* Headphones: Sennheiser HD800
* Power: Furman PS-8R Series II (just because the front outlet was handy. I think the Mytek and Monitor ST might have been plugged into the Furman PL Plus-C)
Misc
The Dangerous Monitor ST requires isolation to prevent damage on the inputs/outputs if you intend to hot-plug anything. Also, since the output is a balanced XLR and the m-stage only has RCAs, I used what I had available and put an ART DTI between the ST and m-stage. Since I had that on one path, I thought I should muck up the signal chain to the HA-1 with a
different isolator, so I put my Radial TWIN ISO Passive Line-Level Isolator between the ST and the HA-1. I think the m-stage got the short end of the stick here. I should have switched them around after the first round of listening but life's too short.
Why my impressions are invalid
* Monoprice XLR cables.
* I had too much in the signal chain.
* Not enough burn-in.
* It took me 4-5 seconds to switch between the HA-1 and m-stage (push the output selection on the ST's remote, plug the headphones from one to the other). That is 4-5 seconds too long to do A/B comparisons. Plus I obviously knew what I was listening to.
And yes, the majority of this section was for the insecure types among us.
Impressions
OK a huge set-up, so where's the payoff? You've patiently read this far, gently shaking your head at the clusterduck (that's pronounced "cluster-DAC") that's certainly coming.
I spent way too much of my life listening to the first 7-8 seconds of the beginning of both songs focusing on subtle details such as the pluck of the strings and the tap on the guitar body in
Sand, and on
Beat It I mainly focused on the bass drum. What did I hear between the two? Well, not much. If you were to ask me to do a blind listening and A/B the two I wouldn't be able to tell you which was which.
In any case, the attack and definition was slightly better on the HA-1. I could hear it mostly on the bass drum in
Beat It where the m-stage made it sound just slightly flabbier (as if the skin was looser on the drum). The HA-1 was a bit tighter with just a touch more click. I'd attribute it to better attack/transient response.
That's it. I'll take complaints on tricking you to read this far via PMs. No wait. No I won't, sorry.
Summary & what I learned
Am I saying you shouldn't buy the HA-1 or that the much cheaper m-stage is better somehow? No, I'm what I'm really saying is that you should listen for yourself (if you can. If you can't, continue to live vicariously spending other peoples' money by reading this forum or read enough opinions and take the shot, pull the trigger, some other bad analogy or is it simile?). And "no" especially if you look at the chain I used.
The most important piece of gear I used? This:
Yes, that is a CD-R sticky taped to a "precision instrument". Well, technically it isn't; It's actually a CD-R sticky taped to a piece of cardboard that's wrapped around a "precision instrument".
Anyway, why is this monstrosity the most important part of my impressions? Simply because I used a pink noise generator (namely Room EQ Wizard) to match the volumes of both amps. The CD-R just helped me get to some semblance of isolation, stability, and consistent placement when switching things around. If I was off even a tad more than what the fluctuation on Fast mode would show, I was hearing details on one amp and not the other. Level matching was what I alluded to being the difference between the DSD and PCM version when I initial gave my "wow" comment. After simply using the PCM version and concentrating solely on the amps I think that's what was going on (the DSD version got bitstreamed you can't adjust the volume on JRiver in that situation so getting a good level match between the two files is more trouble than typing in this tripe I'm writing right now).
The second takeaway? Life's too short to do this. I'd rather sit back, relax, and enjoy the music.
The third? Hats off to all the people on this forum who put in the (money) time and effort to write reviews for others. It almost makes the inevitable trolling worth the while. No, I take that back. Trolling is never excusable.
And on that bombshell, Happy Mother's Day everyone. And to those that don't believe in "mothers", happy Sunday (unless it's already Monday for you. If so, I'm sorry I ruined the start of your week).
//Tomi B.
