JesseDodds
- Jan 3, 2010
Hey guys,
Been lurking for a while and decided to finally sign up and join in on the action.
I've just ordered a Little Dot MkIV SE & DAC_I and was wondering if you prefer USB or TOSLINK to connect your computer up to your DACs. Is there much discernible difference between a run-of-the-mill USB cable vs something like the Synergistic Tricon USB cable.
If the preference is leaning towards TOSLINK, can you recommend any decent cables to look into (toslink to toslink mini) - >$100.
Cheers guys
Cheers guys
