ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Discussion in 'Portable Source Gear' started by t.r.a.n.c.e., Sep 11, 2015.
983 984 985 986 987 988 989 990 991 992
994 995 996 997 998 999 1000 1001 1002 1003
  1. csimon
    I just took a look at this, but despite declaring itself as being the player for audio fans, it doesn't know about Album Artists.
  2. addyg
    I have used a nice 2.5 balanced cable from a HK real shop. It is about usd80 come with most terminations for IEM. Copper plated silver 4 core. Look for "R-Studio" in facebook you should be able to find. This is a real shop so people listen to cable before they buy.
    Psycho-Prof and DBaldock9 like this.
  3. addyg
    Thanks for the info
  4. nam1210
    How's the bass of dp-x1a?
    Anyone can compare dp-x1a to opus #3?
  5. addyg
    It depends on your IEM more than the player. My ath-e40 is quite bassy (by depth not by amount) on dpx1 2.5
  6. addyg
    IEM line up on dpx1 3.5 unbalanced:
    (Personal opinion)
    iSine20 > Xelento Remote >= Campfire Andromeda -white > ath-CKR100 + factory upgrade cable > Sony EX1000 >= ath-e40
    alphanumerix1 likes this.
  7. bclark8923
    Question, can you use the X1 or X1A as an external dac for your laptop?
  8. strooper
    Not as far as I can tell. I've looked for a third-party app that might enable the X1's use as a USB DAC and haven't found one.
  9. Tennessee
    Yeah, sadly the same.
  10. addyg
    FYI
    Music app just got updated
  11. snafu1
    This update looks kind of minor. Just fixed a few bugs and enabled Onkyo Music Downloader. But it's good to see that the are still working on the Music App
  12. maddib
    ... and it introduced at least one major bug . After I updated the app, USB audio output got useless. No joke - since the update, music from FLAC files actually grinds! Analogue output is o.k. After getting back to the original app version, the USB problem disappeared. So, it really is a new bug in the latest app version .
  13. adalberto vela
    What do you mean by grind..? Also, exactly what do you mean by USB audio out..? Will this affect the micro USB OTG connected to a separate dac/amp..?
    How did you you get back original app..? Sorry for multiple questions:)
  14. maddib
    Do you know the strange sound of music played back by a tape deck that is not able to drive the tape with a constant speed? Very strange behavior for a full digital stream.
    Yes, it's the micro USB output. I don't know if this problem is restricted to certain types of audio file formats. At least with FLAC files the problem is unmistakable.
    Go to settings/apps. Tthere you can restore the app version to the initial/first one.
  15. Tennessee
    For me 1.6 music app update broke playback (music was skipping), so I prefer just stay on stock...
