ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Mar 24, 2017 at 10:39 AM Post #14,148 of 16,326
FYI the pioneer Bluetooth remote control app is available from Japan Google Play Store and Apple App store Japan. If someone can find it please share the apk.
Mar 24, 2017 at 12:10 PM Post #14,149 of 16,326
Hi ! Everyone...
Just wondering if someone has DP-X1A's update.zip.
I bought DP-X1A and tried to root.
I deleted the google play store accidentally.
I tried to solve this problem but it is getting worse.
Now the DP-X1A is completely dead, after wiping to factory settings, the screen will stop at the wifi searching only.
Please help...thank you
Mar 24, 2017 at 1:28 PM Post #14,151 of 16,326
I did have the 2002 with the x1, a gorgeous pairing!
No sibilance or anything.
If you mail dunu in CN they send you a 2,5mm TRRS cable for round about 130 dollar. Pure copper and very good quality!
Mar 24, 2017 at 1:39 PM Post #14,152 of 16,326
Hi ! Everyone...
if you can get into stock recovery try and flash this https://android.googleapis.com/packages/ota/onkyo_raizin32_raizin32/1295292967f8c11f806630c670f0d2b3e0189588.zip  its stock firmware for it
Mar 24, 2017 at 10:19 PM Post #14,155 of 16,326
  so i finally got my balanced cables from PLusSound....i seem to find the that with the balanced cables [using shure se846]  soundstage seemd to be a bit "wider" , more depth,....what i seem to be missing to be missing is the "louder" part.... i read somewhere that when usig in balanced mose music will get louder so if you are used to say volume level of 130 in single ended it should go down when using balanced ..... this did not happen for me.... both with balanced out and ACG...... i actually expected more from balanced out as the manual sais with ACG volume levels will be about same.... so what gives?? why didnt i get louder playback sound in balanced ??
You must have "auto volume enabled", it takes the volume down by 50% or so once balanced connection is detected.
Mar 24, 2017 at 10:52 PM Post #14,156 of 16,326
Oh great, my DP-X1's SE socket is getting loose now. Slight movements to the plug will cause it to get dislodged. With straight plugs, I can get it to stay connected; however, with right-angled plugs, the issue is very prevalent.
Mar 25, 2017 at 1:48 AM Post #14,158 of 16,326
Mm...have you tried contact cleaner on cable plugs? I use it and finish it with Cardas cleaner (bought from Moon Audio). It solved intermittent signal loss on my DPX1 SE.
Thankfully, I haven't experienced any loss in signal with my DP-X1. The socket is simply loose, which results in 3.5mm jacks popping out ever so often. A friend of mine has the exact same issue, only worse.
Mar 25, 2017 at 3:07 AM Post #14,160 of 16,326
Hi ! Everyone...
Grab the firmware here (link from this post)
https://android.googleapis.com/packages/ota/onkyo_raizin32_raizin32/df30d6331a9d059b201363a70c664bed92470bf2.signed-Onkyo_32G-ota_update.zip
-Rename it into update.zip, copy to /sdcard
-from the recovery, select Update from SDCard
