ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Mar 30, 2016 at 2:18 PM Post #6,721 of 16,267
AudioMan2013
Thinking of getting the DPX1, but I worry that Tidal won't work when used as a transport to my Hugo.
Does anyone have any experience running onkyo as a transport to an amp?
I ask this because Tidal won't work when used as a transport from my Samsung Note 4 running Android 5.1.1
Have you tried using USB Audio Player Pro to output to your dac?
Mar 30, 2016 at 2:41 PM Post #6,722 of 16,267
Jimmy6
I have tried using it with the note 4 and while it works, it's a bit finicky. It won't play the songs I've searched and chooses to play another song in the album instead.
Sometimes I'm lucky and it will play the song I've selected if I play from an album, but this kind of playback ruins the experience :frowning2:
Mar 30, 2016 at 6:10 PM Post #6,724 of 16,267
ptolemy2k6
could someone clarify something for me:
how does balanced connection works? I assume that in order to have it, all has to be balanced... for example 4pin xlr balanced adapter to 2.5mm balanced will work. but I also seen some 3.5mm to 2.5mm balanced adapters? how would that work if 3.5mm is not balanced initially?
Mar 30, 2016 at 6:20 PM Post #6,726 of 16,267
rmoody
Knoxville, TN
There are 3.5mm TRRS balanced capable connectors, I know I bought one because apparently I can't read.
Balanced must have a completely isolated + and - wire going to each transducer (4 total wires for stereo). Single ended would be sharing the ground so only needs 4 wires, + and for each channel and a shared -.
Mar 30, 2016 at 6:22 PM Post #6,727 of 16,267
ptolemy2k6
oh, good. that's what I assumed. I am sure there are some 3.5mm trrs balanced out there, I just was making sure...
Mar 30, 2016 at 7:09 PM Post #6,728 of 16,267
rmoody
Knoxville, TN
Come on over to the DIY cable thread, lots of great advice and eye candy (some of which I need to be uploading).
http://www.head-fi.org/t/676402/diy-cable-questions-and-comments-thread
Mar 31, 2016 at 1:15 AM Post #6,729 of 16,267
Raddiqal11
Hello, I'm a small time cable maker and some people have requested 2.5mm balanced for the onkyo dpx1. The thing is I've done, from tip L+R+L-R- and the ak spec from tip R-R+L+L-. Both ways work with the onkyo player can anyone tell me why?
Mar 31, 2016 at 4:49 AM Post #6,730 of 16,267
masterpfa
I would not thought they would and probably safest to stick to the recommended layout I would have thought.
Mar 31, 2016 at 5:33 AM Post #6,731 of 16,267
georgelai57
I'm a bit late to the game but what is the exact name of the stock music player so that I can find it on the App Store to update? Is v1.0.2 the latest? Thanks
Mar 31, 2016 at 5:38 AM Post #6,732 of 16,267
masterpfa
The app is called Music and it is by the Onkyo Corporation
Mar 31, 2016 at 5:40 AM Post #6,733 of 16,267
georgelai57
That's what I thought but in the Play Store after I key in the word "Music" it gives me a whole lot of choices but I don't see the stock player.
EDIT: Okay found it. Key in the word "Onkyo" and scroll for it.
Sorry but I dislike Android.
Mar 31, 2016 at 5:52 AM Post #6,734 of 16,267
georgelai57
I like to delete as many apps as possible because I use this to play music not to do ANY other thing. Can I delete these two apps - Google Play Services 92.66MB and Google App 50.96MB? What do they do?
