Subhakar
- Nov 26, 2015
Mine DP-X1 shipped. Hail PriceJapan.
So is pricejapan the only real game in town currently, or are there other places I could order from? I'm back in as I am sick of carting a phone around with an amp and all the damn cables! Man does that clutter annoy me.
I CAN'T SLEEP ANYMORE!
I KEEP DREAMING OF ONKYO DP-X1 I CAN'T WAIT ANY LONGER NEED IT NOW NEED MORE REAL WORLD INFO FROM HEAD-FI BRO'S & GAL'S ARGHHHHHHHHHHHH!
(It's like Dark Souls, DSII, and Bloodborne all over again).
That is dangerous. might turn into chronic condition, watch out -
I believe the balanced headphone input on the DP-X1 is 2.5mm is this correct? Thanks.
^^ I almost bit again and bought a used ZX2, but I can't bring myself to pay more than $550 for it. As good as it sounds, it is just not offering enough for the price people ask. I feel bad for all the ZX2 owners that will want to sell used (and I know many will want to keep the ZX2) as there is no way people will pay anywhere near the retail for a ZX2 with the X7 and DP-X1 now available, plus others soon to come I'm sure. I know I would love the ZX2, but the power issue would be a problem for sure.
Hi guys, a quick question.
First, a premise:
My aim is if I want to use the Onkyo DP-X1 DAC in balanced mode but use an external balanced amp for home, and possibly portable, use, then I want to output a balanced signal into an amp that can receive a balanced analogue input (not digital or OTG).
So far the only DAC/amp that I have found that can either receive a digital OTG signal to it's own DAC, OR receive a balanced LINE IN just to utilise it's balanced amp circuitry, is the ALO Continental Dual Mono (CDM).
Now why that's significant is this: if I want to use the balanced dual DAC's of the Onkyo DP-X1 but use a more powerful balanced amp, then outputting the DP-X1 signal via balanced 2.5 mm output into CDM 2.5 mm input will achieve this.
If for some reason I want to use the DP-X1 as a transport only (bypassing a computer, which is for me the ONLY reason I would do this) then I can use an OTG cable and bypass the DP-X1 DAC and amp and use the ALO CDM's DAC/amp (or Chord Hugo/Mojo, Sony PHA3, name you're own amp or DAC/amp combo).
Unfortunately I cannot afford the ALO CDM.
My question is this:
Is there an amp that is portable that has BOTH 2.5 mm TRRS balanced inputs and outputs that is not the ALO CDM and cheaper?
No, it's not.
There is no 'input', digital or analogue, on the DP-X1.
However, it does support 3.5 mm unbalanced (TRS) and 2.5 mm balanced (TRRS) outputs, as well as OTG digital output (bypass all internal DAC/amp circuitry).
2.5mm TRRS balanced is less common than 4-pin RSA/ALO balanced connectors. If you are willing to sacrifice the smaller form factor of the 2.5mm balanced and go for the slightly larger RSA/ALO connectors there are numerous portable amps that have an RSA/ALO input and an RSA/ALO output that are fully balanced through and through and never convert to SE. A few I would recommend looking at are:
1.) Ray Samuels Audio SR-71B
2.) ALO Rx Mk3 B+
3.) Cypher Labs AlgoRhythem Duet
Each of these three amps can be found (especially in the Head-Fi classifieds) for much less than the ALO CDM and they all perform quite well. The only thing you would need to connect to the DP-X1 to it would be a 2.5mm to RSA/ALO cable which can be made / bought from several locations. Also, if you are interested in fully balanced DAC / Amp combos that accept USB input there are too many options to list as they are much easier to find than stand-alone portable amps.
- InsanityOne
Thank you, output is what I meant (although technically the plug is an input hence why I mistakenly used the term input). Cheers.
