ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Discussion in 'Portable Source Gear' started by t.r.a.n.c.e., Sep 11, 2015.
144 145 146 147 148 149 150 151 152 153
155 156 157 158 159 160 161 162 163 164
  1. ravensnest
    2 adapters + 2 512GB SD cards + 32GB intern = almost 1 TB storage. Is this possible?
  2. alamakazam
    I don't have 2 adapter, but most likely it should work
  3. DGG32
    Is there a possibility of a usb dac functionality being implemented in the future?
  4. Uncle E1
    balanced  [​IMG]
  5. 3ggerhappy
    so how does it sounds on balanced?
  6. Uncle E1
    really good!  it is almost 3x the single end output!
  7. Subhakar
    Why is it that despite the device being out in the real world for over a month nobody has found out if twin DACs are used in SE mode or just one?
  8. ReizeiMako
    I believe most of us here still waiting for unit shipment. Only few people has it right now and seem no one know an answer for your question.
  9. nanaholic
    It's single DAC and single amp for the SE - it says so on the website, just that the people either keep ignoring it or couldn't read Japanese to notice it.
    See that x1 right at the bottom there compared to all those x2 pasted everywhere above?  Yeah, that.
    So if you are buying this DAP and wants to utilize it to the full, be ready to invest in a balanced cable/headphone, if not and you aren't planning to go balance either may as well just go Pioneer instead.
    georgelai57 and Uncle E1 like this.
  10. nanaholic
    Local audiophile store happens to be carrying official Fitear balance cable so picked it up yesterday, spend yesterday and today listening using balance only.
    The MH335DW driven in normal balance mode is almost too overwhelming with the low end, much better control in ACG mode and low gain setting and needing about 70 notches in volume.  I like to turn on DSP and apply the slow filter which smooths out the edge of the sound a bit as well.
  11. Subhakar
    Thanks.
  12. holmieSG
    Worthy to upgrade from ak240 based purely on sound? I will be using it balanced
  13. mysony1
    Is a great piece player. But if you asking whether is it better then ak240, 240ss or 380.
    All I can comment is a different sound signatures. However is worth what you pay for.
    Sent from my iPhone using Tapatalk
  14. hc524
    What are people's thoughts on the upsampling quality on dpx1?
  15. callizer
    Does changing the default launcher to Google Now or Nova Prime affect the sound quality or functionality in any way?
