ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Discussion in 'Portable Source Gear' started by t.r.a.n.c.e., Sep 11, 2015.
  1. Teppka
    Found it. Increasing gain to high improved max volume somehow. Is there any other settings you recommend to look at? Left volume limiter on Max, lock range at Normal and Digital Filter on Sharp. Fixed line output made no difference in max volume probably because it already is on Max with High gain.
  2. howdy
    There are 2 gains one in setting with android and one in the onkyo music settings.
  3. Teppka
    The one I found is in Settings - Sound&Notifications - Gain Settings - High. Could you point me to the second setting?
  4. Teppka
    There is a ReplayGain setting in Onkyo music player. Is that it? If enabled it has two settings, Preamp for tracks with/without replaygain info. Is this it? If yes will it effect only music player through this player or across whole device also affecting Spotify? Thanks.
  5. Teppka
    I have Oppo HA-2SE and have just received Onkyo DP-X1A. Even though I did increase gain on Onkyo to maximum I still am not satisfied with how it drives my Oppo PM1 and PM3. Oppo HA-2SE is where PM1 really shines. Though I didn't try balanced yet, both balance cables for PM1/3 are on the way. Did you move forward with getting another DAC for your PM1 or purchased Oppo HA-2SE? Now that they stopped producing new models this is the latest one you will ever get.
  6. innocentblood
    I've sold my Onkyo so that I could get the Chord Mojo Poly. I find that my Oppo PM-3 sounds the best thus far with the Chord Mojo Poly setup.
  7. bluedolphin
    I will buy Onkyo dp-x1 but when i went to several store here in spain
    and click purchase
    i then get a email from shop saying is not Avaible because Onkyo has discontinued Dp-x1
    I got this from several shops
    Now i dont know what to do i realy wanted to buy this player
    Distribuitors making it very complicated in spain to get Onkyo Dp-x1
  8. Teppka
    That's because there is a new model Onkyo dp-x1a :)
    Try buying this one.
  9. bluedolphin
  10. Teppka
    I believe it's DP-X1-B for EU which I believe the one having volume limit which you can actually overcome. Or you can order from US the DP-X1A one. Amazon ships internationally.
  11. bluedolphin
    Teppka how can i overcome the Volume limit, select Usa as country (thats what i do on other players) ?
    yes you right Dp-X1-B is the one for europe
    I hope thats not discontinued
  12. Teppka
    In case you buy EU version
    https://www.head-fi.org/posts/14282283/
  13. bluedolphin
    Thank you so much, i guess Variable line out mode is in settings?
  14. Teppka
    I believe so. Mine is not EU unit, so I don't have it.
  15. bluedolphin
    Eu limit comes from France where it started
    im not in france so i might not have the problem, but thanks for sugestion
