home44
- Nov 26, 2016
Kilpsch X12 Earphones
Don't really know to much about those but it seems like the cable is not detachable and you will not be able to use those in the 2.5mm socket. If you are wanting to experience balanced sound you will need different headphones/IEMs.Kilpsch X12 Earphones
Yes, it has. But this can be reversed by a setting: enable the "Variable line out mode" and now the limit is gone. And yes, headphones can be used with the variable line out enabled.Does this device have the eu volume limit on as the Pioneer XDP-100R did?
I have ordered one of these...
https://www.amazon.co.uk/dp/B078YKMYHK/ref=pe_3187911_185740111_TE_item
That's not going to give you balanced sound? You need balanced cable
Just like said above it will not work. Your cabme already needs to be R+R-L-L+ and that cable is not. Just because you buy a TRRS adapter does not make your TRS cable a TRRS.I have ordered one of these...
OK Thanks.
That should be https://www.linum.dk/Linum Cables (linum.de) are quite remarkable.
I recommend the Fender/Aurisonics lineup for IEMs as they have a signature to suits most tastes and their ‘heavy’ offerings are second-to-none. Also available worldwide afaik.
How much do you want to spend and what kind of sound sig do you like? Lots of bass or very articulate...Like I said earlier I'm more than happy to buy some balanced earphone but have no idea where to start looking manufactures etc.
I'm in UK btw.
