ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
post-14044255
Post #15,406 of 16,174
simaster
Moscow
Moscow
Hello DP-X1 users,
what headphones are you using with balanced output? I use Onkyo CTI300, but with regular phone output. I heard a lot about sound improvement with balanced output and I would like to try it :)
Please, advise.
post-14044305
Post #15,408 of 16,174
meegja
The Netherlands
The Netherlands
Website
www.3dart4u.com
Hello DP-X1 users,
Please, advise.
Difficult to advise because the sound/signature of headphones depends also on the preferences of the user.
I have the Dunu DK-3301 in-ear headphones and I absolutely love them But others will not like them because they have a very natural sound. People who like a more warm sound will not go for the Dunu DK-3001.
Also for example: bass. Some people want to have a more heavy bass sound/signature. With my DK-3001 the bass is certainly there but it is not heavy. I do feel them more then that it is audible (if that makes any sense :) )
About the balanced output ... there is a difference but it is very little. With my IEM's I only notice it a tiny bit in the high tones, they are a tiny bit more "clear".
So, if you want a clear, natural sound, the combination of Onky DP-X1 and the Dune DK-3001 is a great combination because they both are natural sounding.
post-14044366
Post #15,410 of 16,174
simaster
Moscow
Moscow
Thank you! You opened DUNU 3001 for me -- I had heard about DUNU, but counted they are not mature to create something really worth to look at. Hm, this is a good reason to go to a sound shop for listening!
post-14046925
Post #15,411 of 16,174
anyworld1209
Middle Earth
Middle Earth
Hello DP-X1 users,
Please, advise.
Try AKG N40 if you like Vshape signature. Sounds pretty great. But i still think something is missing.. Maybe lack of sub bass.. :-?
post-14046947
Post #15,412 of 16,174
CoCostanza
Sweden
Sweden
Hello again.
Well I bought my Dpx1 for a week ago and the sound was very clear, good seperation and spacious. And I tought it is going to get even better with burn in.
Two days ago I stopped being carefull and let the device run nonstop. Today (its been playing for 35h with no paus) I tought I give it a try and listen to see if theres been a change. And omg, the sound is really really really bad. Seperation, clarity and that black background is totally gone. All voices sound like you are listening to cheap broken earbuds. Bass has zero control and is all over the place.
Im panicing!
Have I ruined it by let it run for 35h in a straight? A defect device? What to do?
Any help would be appreciated!
post-14046962
Post #15,413 of 16,174
meegja
The Netherlands
The Netherlands
Website
www.3dart4u.com
Hello again.
Im panicing!
Did you left it attached to a power supply? Cause 35 hours playtime on itself is not possible. Most you will get in 1 run is around 16 hours but 12 to 14 hours more likely.
post-14046978
Post #15,414 of 16,174
meegja
The Netherlands
The Netherlands
Website
www.3dart4u.com
Ah no, Dunu does make some really good stuff. All the reviews of the DK-3001 are really positive, has a great value for money and I only can acknowledge that. Having said that: the sound is excellent but the comfort can be an issue. They have a weird way of putting in (the bud has to go straight in the air-canal and not in an angle like with other buds) and the feel on your ear can be irritating. I myself had just some small issues with it, I got used to it rather soon.
post-14046985
Post #15,415 of 16,174
CoCostanza
Sweden
Sweden
I didnt left it attached but charge it when it got under 20% and then removed it.
post-14046990
Post #15,416 of 16,174
meegja
The Netherlands
The Netherlands
Website
www.3dart4u.com
Then it has not played cause that 35 hours of play is not possible.
Do you have other earphones to test with? Just to make sure your headphones are not the guilty party?
post-14046998
Post #15,417 of 16,174
CoCostanza
Sweden
Sweden
It ran for 9h then I charged it to 100% and then I did the same thing like 4 times. So its been running for 35h with no stop.
Yes I have. With two other earphones. I have turned it off right now.
post-14047313
Post #15,418 of 16,174
ryaneagon
USA
USA
Anyone know if I can use a micro usb out to 3.5mm headphone jack adapter with the Onkyo, I was wondering by doing this would it disable the amp and DAC section? I was going to use mine with a headphone Amp to drive 300ohm cans, I just didn't know if there might be a better way than just the 3.5mm to RCA way. Cheers!
post-14047752
Post #15,419 of 16,174
ryaneagon
USA
USA
I just picked up a set of Beyerdynamic DT 1990 Pro headphone (250ohms) I'm looking to use the with an Onkyo DPX1A portable Hi-Res player and need a headphone amp, Unfortunately I don't have much budget to start with, I was looking at the Schiit Magni 3 http://www.schiit.com/products/magni-3
or the Schiit Vali 2 http://www.schiit.com/products/vali-2
The Magni has more power and is solid state, the Vali has a bit less power and has a tube (pre) and solid state amp, being I'm not able to demo these, what do you recommend?
I was leaning towards the Magni, I just can't see a single tube pre add any extra warmth to the sound.
Thanks!
post-14047974
Post #15,420 of 16,174
howdy
Minnesota
Minnesota
You can go USB out to another source like an amp and it will use the Onkyo DAC but if it has its own DAC it may bypass the onkyo AMP and DAC. What are you going to use as an AMP?
Users Who Are Viewing This Thread (Users: 1, Guests: 8)
  • Top
