OnePlus One
Feb 23, 2015 at 5:52 AM Post #125 of 203
playingwithfire
I find the treble unbearable on those.
Feb 24, 2015 at 9:35 AM Post #127 of 203
worminater
So update: I fixed my root; which also fixed Viper4Android mod (which is awesome btw).  Sounds surprisingly great with my se846s. I then went to install the new OTA; and it failed; but with reinstalled CWM i can see the console...
assert failed: apply_patch_check("/system/etc/audio_effects.conf".....
This looks like a side affect from V4A I think; i'd have to do a factory reset it appears. Doh. I'll probably leave as is for now, and do a manual flash to the next major release whenever it hits; hopefully more stable.
Feb 25, 2015 at 2:34 PM Post #128 of 203
dannytang
Toronto, ON
Hmm... I have V4A and was able to update to 05Q, initially it failed (probably a side effect of having rooted the OPO). I found this thread and followed the "instructions" and was able to update: https://forums.oneplus.net/threads/fix-assert-failed-errors-when-flashing-cm-11s-05q-in-twrp.265865/
Feb 26, 2015 at 9:00 AM Post #130 of 203
worminater
  Why use Viper4Android? Use Maxxaudio on CM12.
V4A may or may not allow the OPO to output in 24/192 like it can stock. Maxxaudio sounds much better as well.
Does MaxxAudio improve or hurt sound quality on CM12? I've read both now I think.  Much confusion.  I'll find out first hand eventually.. :)
Mar 3, 2015 at 5:42 AM Post #131 of 203
Axesd
Anyone even bother to use a portable USB/DAC?
Mar 3, 2015 at 6:04 AM Post #132 of 203
mannp
I am wondering the same thing as I try to use my oneplus as a transport for my hugo.
Currently its a big fail for me, but still researching.
I thought Lollipop was supposed to support dacs out of the box... but running on cm12 my hugo is not recognised.
Mar 3, 2015 at 1:43 PM Post #133 of 203
worminater
What cable are you using to connect?  My OPO picks up my C5D as expected.
Mar 3, 2015 at 5:39 PM Post #134 of 203
mannp
The usb cable that came with the hugo and a startech otg cable.
Mar 4, 2015 at 5:24 AM Post #135 of 203
Axesd
I just stayed stock running XNPH05Q update. I have an iBasso D-Zero I bought a few years back. Pretty much plug-n-play in my case, but It gives me sibilant whenever a song ends.
