OnePlus 3 Audio Quality?
Dec 23, 2016 at 11:45 AM Post #46 of 52
Agent of Chaos
but if you provide evidence that they don't, I will change my opinion of course :)
Xplay5 Elite (2x sabre 9028): http://www.gsmarena.com/vivo_xplay5_elite-review-1456p7.php#aq
Lg v10 (sabre 9018): http://www.gsmarena.com/lg_v10-review-1333p7.php
Lg v20 (sabre 9218 Quad): http://www.gsmarena.com/lg_v10-review-1333p7.php
Axon 7 (Akm 4490, They crippled this one so much here): http://www.gsmarena.com/zte_axon_7-review-1512p7.php
Now the Mi5 (Qualcomm wcd9335): http://www.gsmarena.com/xiaomi_mi_5-review-1411p6.php#aq
Dec 23, 2016 at 12:40 PM Post #47 of 52
mcmalden
Now the Mi5 (Qualcomm wccd9335): http://www.gsmarena.com/xiaomi_mi_5-review-1411p6.php#aq
Thanks man! The stuff on the volume levels is really weird indeed, the graph that I posted in this thread previously clearly shows that the V10 has more than double the dB as opposed to the Galaxy s7. Its really not scientific the methods that they are using.
In terms of performance, all these numbers could be explained by bad amplifiers as far as I can tell. But it is definitely fishy, also considering the errors they apparently make in the screen measurements. I will keep this in mind in the future
Dec 23, 2016 at 2:56 PM Post #48 of 52
Agent of Chaos
Definitely not, They use active external amplifiers when testing these smartphones, So blaming it on bad amp is not a valid explanation (plus the devices we mentioned has better internal amp than Mi5 if you are concerned).
Jan 14, 2017 at 7:35 PM Post #49 of 52
almarti
Spain
I want to connect my OP3 to Chord Mojo so I need a USB C to microUSB cable.
Can anyone tell me which is th right one? Any configuration needed in settings? Its updated to Android 7.
Thanks
Feb 23, 2017 at 10:47 PM Post #50 of 52
superuser1
Sapta Sindhu
To be honest i am pretty underwhelmed with the lack of power with the OP 3t. I confess i dont have the most efficient iems but i do have the Meze 99c and they are pretty darn efficient and with those even i find the depth the output lacking. I had great expectations from the 821.. hopefully an update will miraculously solve this.
Feb 23, 2017 at 11:10 PM Post #51 of 52
cswann1
DHL delivered my new OnePlus 3T today  (48 hours from China to TX.....not bad)
I copied a chunk of my music library and plugged in my UE TripleFi 10's.  I'm more than happy with the way this phone drives my TF10's.   However I should make the caveat that I immediately flashed Resurrection Remix (7.1.1).  My media player is Neutron with crossfeed enabled and a bit of EQ to bring my IEM's more to my liking.
I don't claim to be anyones audiophile, but I know bad sound when I hear it and after a couple of hours of listening, I've found nothing to complain about.
Thanks
https://www.amazon.com/AUKEY-Adapter-Type-C-MacBook-Google/dp/B01ANLA6OU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1487910983&sr=1-1-spons&keywords=usb+c+to+micro+usb&psc=1
May 11, 2017 at 6:14 PM Post #52 of 52
almarti
Spain
https://www.amazon.com/AUKEY-Adapte...r=1-1-spons&keywords=usb+c+to+micro+usb&psc=1
Thanks, finally I got this one and works properly with UAPP and Chord Mojo. Impressive SQ.
What a pity UAPP does not play Tidal offline
http://meenova.com/st/p/mbc_c2mu.html
