Terminator 2 /+ can be configured to work with various I2S formats. There are 8 different configurations. I think you will have very good chance of success.
But you can always reach out to Alvin with Rockna's I2S configuration and I think Alvin can help confirm the compatibility.
I had the Terminator 1 and then added the dsp board but nvr the Terminator 2.
Everything SQ related is better with the Tplus and rightfully so at higher $ range ... especially when you synced compatible Denafrip products e.g. Avatar cdp or even ddc to play with components without clocking facility.
One key recent development is that I had received an updated Hermes (previous was 1st few units with femto clock) with oxco clock and dunno what other magic but usb out of Antipodes to Hermes now sounds better than directly to usb input of Tplus
Had a t+ Since last December. Dac has been replaced by rockna signature which is on much higher level at dynamic, transparency, texture and details.
Just thought to someone looking for an upgrade
When connecting the clock cables between the Denafrips DDC and the Denafrips DAC, look at the clock spec printed on the DAC and the DDC i/o's and connect accordingly, don't use the picture example from Denafrips or you can get your signals crossed- pun intended.
