ccbass
- May 22, 2010
I've been attempting over the past few weeks to jump into the high quality audio world. I'm a bit lost on how things work, why components are used or not used, etc. Hoping some of my science-y questions can be answered.
What exactly is volume?
From what I can tell, it is how much the amplitude of a signal is changed. Now is that "boosting" of the signal measured in volts or amps or what? I head that for a +3dB change, it requires twice as much power as before? Lets say an amp is rated for 500W RMS. Does this mean that as you turn the volume knob up that the amount of Voltage being outputted is becoming greater? Or is it the amps that changes?
What is the difference between voltage and amperage in terms of amps and headphones and how does it relate to impedance? I realize that voltage is the "pressure," amps is the "flow," and ohms is resistance. Now before you jump down my throat about this, I know the basics about them:
R=V/I or I= V/R or V=R/I
W = I x V
Now how does this relate to "drawing current" or amps? I see the term, "drawing current" a lot around the forum. Lets say an amp is outputting 1 volt at 10ohms and it connected to two different headphones. If one headphone has an impedance of 50ohms and the other 100ohms, would the amount of current being drawn in the 100ohm headphone be 1/2 of that of the other headphone. Assume the sensitivity and Efficiency of the headphones is the same.
Now how does all of this relate to output power?
What values change and do not change in an amp? [ie. volts, amps, resistance]
What outputs are typically amp'ed? It seems that normal 3.5mm are most common. Is that why when iPods are used as the DAP people bypass the internal amp by connecting through the dock connector?
It seems as though many "sensitive" IEMS still need to to amped. What is the reason for this? If they have such a high sensitivity, why do they need to be amped? Impedance?
http://www.head-fi.org/forum/thread/17179/please-explain-headphone-sensitivity
What is a channel? Does this just mean left vs right, etc?
I feel like I need to be a physicist to understand all of this. I love learning all of this kind of stuff, but I've hit a wall.
W = I x V
