Official X7 beta firmware (Android 5.1) download and discussion thread -- FW3.0.6 beta
Nov 16, 2016 at 5:21 AM Post #121 of 297
It seems to work on my windows 10 machine, It also works sometimes on my linux machine, but crashes most of the time.
charging also takes a lot longer, i've had it on a 2.1A 5V charger for 9 hours and it is only at 85%, while before, on fw 2.0, it would take about 6 - 7 hours to fully charge. same cable, same charger.
Hi, CH23
For the Linux system issue, we will give this feedback to the engineers and find the reason of it.
For the charging issue, do you charge the X7 when turning on and using it? Please try to test the charging time by turning off the X7 to see whether it helps?
Nov 16, 2016 at 7:56 AM Post #122 of 297
  Hi, CH23
regarding the linux issue: i'm running the Trisquel GNU/Linux operating system, completely up to date, including the linux libre 4.7.5 kernel. the program i used when it crashed is MPV. the file has an AAC, 96kbps, 48000Hz stereo audio file.
Regarding the charging: I have now turned it off, it was at 45%. will check how fast it charges in 3 hours. then I will have it play music using my IEMs, and see how fast it drains.
Thanks.
Nov 16, 2016 at 10:31 AM Post #123 of 297
2.5 hours since i started charging, with device off.
it is at 65%, so 20% over 2.5 hours, meaning roughly 12.5 hours for empty to full
Nov 17, 2016 at 2:49 AM Post #124 of 297
Hi, CH23
The charging time can't be counted like that. If you are convenient, please try to fully charge your X7 and test the time. You can change the USB cable and charger to see whether it helps as well.
Nov 19, 2016 at 12:03 AM Post #125 of 297
Hi, here is the latest beta firmware FW3.0.8_beta for the X7: click here. You may try to update your X7 if you have interest.
Kindly note that that is a beta version and might not be stable enough compared to the stable versions. So please think carefully before upgrading with this firmware.
Nov 20, 2016 at 6:41 PM Post #126 of 297
  Hi, CH23
Hi FiiO,
Finally got a chance to charge it from empty to full, same charger, same cable, firmware 3.0.8b (beta!), turned the device off, took less than 7 hours to fully charge.
I will try to do the same with the device turned on, as soon as possible.
Nov 21, 2016 at 1:17 PM Post #128 of 297
Nov 21, 2016 at 1:32 PM Post #129 of 297
Why not try it?
​I did and v4a does not work after I rooted with kingroot
that's why I am asking if anyone succeeded
Nov 21, 2016 at 3:03 PM Post #130 of 297
that's a better description of your problem :wink:
I'll see if i can replicate your issue. (or if anyone happens to use v4a, please report in)
Nov 21, 2016 at 3:35 PM Post #131 of 297
Has anyone been successful in updating to android 5.1 with windows 10. I followed the steps for updating firmware to 3.0 and the step where you are to open device manager there is no unkown device shown when I connect via USB. Therefore I can't update the driver. Any help would be much appreciated.
Thanks
Ken
Nov 21, 2016 at 8:59 PM Post #132 of 297
I followed the instructions in the video and it worked for windows 10
Nov 21, 2016 at 11:33 PM Post #133 of 297
I too used Win10 for the update. With the device turned off, plug it into your system. Then turn on the X7 while holding the volume up button. Then check device manager. Try this and let me know.
Nov 22, 2016 at 2:14 AM Post #134 of 297
Thanks
Ken
Hi, Ken
Did you try collect the X7 to your computer in this way: power off the X7, connect it to the computer via USB while holding the Volume Up button (the top button on the left side of the unit)?
