nassaubusrider
Banned
- Dec 6, 2003
I dont know what kind of prob I'm having, it could be related to my headphones, booster, or minidisc unit. A volume on my MD of 23 or 24 with the booster was always adequate. But recently I'm finding I have to crank up the MD unit to 28 or 29 to get an adequate sound level. I've checked the batteries in both the booster and the MD unit. I've made sure AVLS is turned off. Still, I'm finding I'm getting very little volume from my MD unit. It seems the soundstage has gotten alot narrower, and the bass less punchy. Now there are problems with two of the units involved. My headphones (my 2nd set under a plan with Radio Shack of now discontinued headphones) appears to be dropping out partially in the left ear. It seems to happen when the wire near the 1/8'' connector moves.
My Sony MD N505, as I posted in another thread, has developed a problem in the "jog dial" where it gets the wrong command or does not respond at all.
I compared the headphones involved and used them with my personal cassette, the volume seems as it always as there. I've connected the booster with the cassette, it provides a high amount of boost, so I dont think the booster is "going". It seems to be an output problem on my MD unit, possibly. I know my booster is kind of weak, and I need better headphones. Two questions. Looking for a small size closed ear headphone with a lot of good bass and gets loud. Anyone know of any for $40 or less?
Also I'm not handy with DIY & dont have a soldering iron, how much would it cost for a cMoy amplifier (the ones in the tins) to be built. I'd like something a bit more powerful than my "booster", as it really doesnt provide enough "ooomph" with the weak Sony MD units.
Here's my portable setup (yeah, I know it's REAL pathetic!)
