Yeah? Hope you like it. I think it sounds much better with the intended comply's BTW than the silicone tips I had fit on them. The seal might have been too tight, as sometimes the bass got out of control and the treble which is pretty strong on this IEM got a little bit too much at times. I think with the comply's they fit as they were designed. I am using the TX-200 M's to keep the driver unit clean. I look in and there's no filter at all to keep anything out. Pretty much what the diagram specs but oh well.
I was doing some listening comparisons with my SE846 blue filter/ IE800 with custom molds/ Donguri Keyaki with both silicone tips and comply tx200 tips.
Driven from my Vega/Taurus MKii stack
Highs: The Donguri definitely had the more piercing highs. I was surprised by this, expecting the IE800 to be the tops on this. The SE846 felt muted. Although, I think the IE800 highs sounded more natural
Mids: SE846 wins here, I think mainly cuz the highs are not as strong. Though depending on the track, all the IEMs are able to do voices very well.
Bass: SE846 is the strongest. IE800 and Donguri are fairly similar. I'd give a slight edge to the IE800. The details of the bass is just better IMO. I think I've grown up with dynamic driver bass more, and it's just clearer defined. Both are very fast. The SE846 has more volume and boom. This was also surprising as I thought the Donguri had too much bass at first. But actually with the proper fitment it's quite good.
Soundstage: IE800 wins out here, no question. Somehow it just sounds more organic and just as open. The Donguri has a nice stage as well, but it's not as inviting. The SE846 while it has it too, it is much more intimate. I think it's still the best for EDM or pop music though. I feel I can go anywhere with the SE846.
This is interesting, and it might be different driven from my portable DAC/AMPs, but I wanted to see how far each could go. When I tried the SE846 and IE800 with the HA-1 before, the IE800 scaled much better. Easy to drive wise, it's from easiest SE846>Donguri>IE800 hardest to drive. That said they're still IEMs and can all be driven from my iphone to a decent level.
