Obscure Chinese DAPs
Discussion in 'Portable Source Gear' started by pekingduck, May 26, 2014.
349 350 351 352 353 354 355 356 357 358
360 361 362 363
  1. trellus
    You did have a backup of your music, yes?
    :frowning2:
  2. CoiL
    Unfortunately NO ;(
    But luckily, that card didn`t contain my all-time favourites. Some music on it was must have though.
    Some I can restore from CDs, some need to be downloaded again ;(
  3. HungryPanda
    wow very unlucky CoiL
  4. cqtek
    What?
    Unpleasant event.
    :anguished:
    Thanks for warning.
  5. CoiL
    Well... all I could restore was few wav files and album art. Flac is all gone and I doubt I can restore it.
    Wont send it to proffessional recovery as it costs sooo much.
    Though, anyone can recommend program for resoring files on SD card? Maybe will try once more.
  6. handwander
    Can anyone identify this? It's Japanese not Chinese but thought I'd ask anyway.
    [​IMG]
  7. cqtek
    Holypal, trellus and hakuzen like this.
  8. Dobrescu George
    That looks really trippy :)
  9. Mr Trev
    Hmm. Kind of looks like something Nintendo would have built in the late 80s
    HungryPanda, AndySocial and trellus like this.
  10. LaughMoreDaily
    Like inside a jock strap?
    AndySocial likes this.
  11. CoiL
    I was luckily able to restore ALL my FLAC music from mSD card that QNGEE deleted.
    I used EaseUS data recovery tool.
    HAPPY DAY! ;D
    cqtek, superuser1, kp1821 and 8 others like this.
  12. trellus
    That's awesome! I felt terrible for you when you said you had lost almost all your FLACs! Make a backup now! :D
  13. CoiL
    From the other thread:
    My short take about QNGEE X2:
    + quite good, clean and detailed sound
    + good build quality
    + good battery life
    + simple and functional menu
    - display wake-up time is too long, ~3sec
    - vol button is uncovered, plastic and moves too easily
    - bright sided sound signature (not good match if not using EQ with chi-fi BA IEMs)
    - can corrupt mSD card while inserting to working X2
    - vol button works also as up-down in most menus (which is confusing sometimes when wanting to raise/lower vol while EQ-ing)
    - only 5-band EQ
    trellus, hqssui and hakuzen like this.
  14. trellus
    Thanks, @CoiL for the impressions - I’ve wondered a lot about that little DAP.
    How fast is it to navigate through the memory card? Do you navigate through folders or using the tag info?
  15. trellus
    @HungryPanda so this is the one you bought and it ended up being rather nice after all, the other user's assessment notwithstanding? :D Does it use Hiby OS? UI pretty smooth?
360 361 362 363
