Dobrescu George
Reviewer: AudiophileHeaven
Shozy Zero with a screen??
Woah, I meant Shozy Alien
I know they have a DAP and that it was well received
They also have Alien+, which has a screen
The Agptek H50 is the same as the Ruizu A50 and if other players from the same company are a guide the firmware would work on either. I have successfully updated my A50 from the Ruizu website without problems but I never had any trouble with it anyway as it has never locked up.I just bought an AGPTek H50 off Amazon, and while it sounds great I've also found some bugs so far.
I saw the firmware update post on the AGPTek website but the instructions are incorrect, the audio tools software doesn't let me select a .HEX file. Anybody else using this and managed to get a firmware update going?
I like the size and shape but I've already found two cases where it completely locks up. I wish these were more hackable, I'd love to do custom firmware on them ):
Alright that worked for me, I renamed the file to "AGPTEK_H50_I"... instead of the filename you need.The Agptek H50 is the same as the Ruizu A50 and if other players from the same company are a guide the firmware would work on either. I have successfully updated my A50 from the Ruizu website without problems but I never had any trouble with it anyway as it has never locked up.
As shown below(though cut off) why do they do that? I'm assuming Power/Enter is Play button so why is the FF/RW on the top right after the earphone slots. just keep Play FF and RW together. Also why is there a VOL button. Would like V+ and V- but I guess you have to press VOL then spin the Knob. Guess the knob does nothing when on the playing screen. Not sure if a deal breaker but really wish it either had volume buttons or the dial would just do the volume in now playing state. Better if the PLAY/FF/RW were together and the Return and then VOL were on the top side. 400 days of design and test yet that is the layout you settled on to control it? Knob only says 360 degree but nothing about pressing it which would be nice if that was Play. Knob also isn't in the most ergonomic place.
Welcome to our new store.
C1 player have gapless playback, any other operation won't cause any silence or click sound except you pause or close the music on the current playing screen,power off etc.
C1 support bluetooth 4.0-4.2 version,and the support Remote volume+/- play/pause control.etc for bluetooth earphone.
I use the Folder Menu and the filenames are truncated like many players that have a simple file system based on the Fat 32 format. The file names on mine are truncated at 23 characters.Alright that worked for me, I renamed the file to "AGPTEK_H50_I"... instead of the filename you need.
I have another problem that i was hoping new firmware would fix, any artist names that are too long for me get cut off. For example, "BADBADNOTGOOD" turns into "BADBADNOTG", however some other parts of the UI can show larger strings and it just scrolls it. Do you have this issue? Is there a fix?
Have to agree that this does look promising. The first time it was mentioned I wanted to just go ahead and get one but I'd just gotten burned by the Xduoo Nano D3 and disappointed by the Nintaus X10.This looks like it could be the perfect DAP for me if it really does have 20+hour battery and not completely insane UI/UX. I asked the seller if it has gapless playback and if it can be controlled with an inline remote and got this promising reply:
Unfortunately there's only been 4 orders with no reviews placed yet and they won't be getting red back in stock for 3 weeks as it's Chinese New Year. I was dangerously close to getting a Sony NW-A37 but hopefully some reviews for this come in and change my mind.
https://www.aliexpress.com/item/Fin...id=71d3f6b8-09a9-470b-940d-0a42590b0e3c&tpp=1
Do you remember if it had gapless playback?I've seen/played with that one courtesy of a friend at work and it looks neat. It's not my particular cup of tea, I already have a Clip+ so not looking for a small player. But I do appreciate the scroll wheel being on the front of the device and it sounded really good. Punchy bass, slightly rolled-off treble, sounded great with some heavy rock (Mastodon, The Sword)
Get the new items the Xunsound XS01 and F Audio S1! Here together with Ruizu A50, front and back
Here with same carrying case, provided with both XS01and S1. Buttons and display looks same. S1 is screwless, with acrylic finish on front and back very well made. Edges not rounded but not too sharp. XS01 has rounded edges in height, but on top and bottom edges are rough and quite sharp, where the removable panels are. So I want to look inside XS01... the
Opamps are Opa627ap, and notice the embossed writing under the play/pause button, says PALY/pause haha.
First observations... both no have gapless playback, S1 have Bluetooth, equalizer (so so quality, and anyway I never use EQ) and an "in" jack that I don't know for what, and resume play working well.
XS01 is more audiophile, no BT and no EQ, two out jacks, a PO out very powerful and a LO out made for sensitive, low impedance phones, actually too weak for my Ultimate Ears ue900s, so I go with PO (that I can't use at max volume, too high!)
The UI is simple on both, S1 is little more complicated due to the lack of power on-off menu and back buttons, the central button works as power on-off by long press, play-pause by click and menu access by short press (around half second) while the left button works as Back (the right button is delete song when in the track list)
A drawback in XS01 is rew-ff, it depends on track lenght... the longer is the now playing track the faster is rew-ff speed! In case of long tracks, 30-60 or more minutes, rew-ff may skip several minutes every second making it uncontrollable, and elapsed time indicator become wrong... Another downside of XS01is resume play not supported... is selectable in menu on or off, but if is set off when turn on the player restarts from the first track in the folder ; if set on restarts from begin of track that was listening to, not from the point where the track was interrupted. Hope a firmware update...
Display clear with white writing, not blue as it may appear on pictures.
Very first impression on SQ... S1 is very good, XS01 is great, that makes forgive the downsides!
Hi, as I can see LO can be used as Line out but being variable not fixed I think is also for phones. At max volume with my ue900s I may use LO when I want listen low level, just can't listen loud. So usually I use PO, carefully as its too loud at max.LO is not made for sensitive, low impedance phones, it's Line Out for external amplification, fyi..
