One of my clients eventually gave up my balanced amp because he enjoyed seriously loud volumes with no-so-effective-speakers. The design makes 1 watt go a surprisingly long distance, much longer than most would think, but there are physical limits.
Mainly, the Ia thru the output tubes. The sensation of audible power would be enhanced if there were more current swing capability. But, that opens up a bunch of other problems, which is why I personally just resigned to using the amp as it is, with it's limitations. I use my amp with big full sized speakers every day, but with moderate volume. At moderate volumes the sound is 'perfect' to my personal tastes, comparable to headphones (with obvious limitations).
Also if the output impedance driving the OT primary were lower, then bass transients would be "more powerful", i.e. the waveform wouldn't bend. The output impedance is determined by two components, the top FET (which as a follower can output some 10 to 50 ohms, depending on the exact type used) and the bottom tube (again, depending on type some hundreds to a couple k ohms output impedance, I think the common TV tubes are around 800 to 1200 ohms).
Now that 1k output impedance is going to bend the big bass waveform much sooner than say a 100 ohm output impedance, or a 20 ohm output impedance.
I did some things to try and go around this, they worked, but created a world of new problems. In the end I personally (I think Sonic agrees as well) think it's better to just accept the limitations and use the amp at moderate listening levels.
Sonic has done really well, the amps look simply amazing and well built. I'm a mad scientist type, my builds look... mad.
Buy amps from Sonic, I want my design to spread to all corners of the Earth.
