Solrighal
- Jan 27, 2005
That's precisely why I gave up with Hifi magazines years ago. All they do is keep themselves in a job.
PTom, you're in an O2+ODAC thread. Take the vitriol elsewhere.
None of us care that you felt a $1000+ amp sounded better than our $65 amp. For $65 I think we can all agree it sounds really damn good.
Btw, I was trying to sell my LCD 2 recently and a potential buyer came to listen to it at my house. He brought a Hugo Chord DAC/amp which cost north of $1000 and it definitely sounded better with the LCD 2 than the O2/ODAC. I didn't do a blind test but I felt there was a big difference. The O2/ODAC is the most expensive setup I had ever tried till that point and I was quite skeptical about the benefits of expensive setups based on what I've read on the sound science part of town till trying the Hugo Chord.
I honestly don't believe it was expectation bias or anything psychological.
Only reason i did the Mouser route was because i wanted to use better components, but i agree the kit form is better value.
Also agree about the front panels aesthetics, i sourced my odac and o2 enclosure from them for that reason. The red/gold PCB is just lovely too, all their parts have a quality feel to them.
Whilst I was paying the shipping I got a second PCB in case I want to build a second o2 later (in a B3-80 with the ODAC as batteries), agree very high quality as far as I can tell.
I like what you did with the separate ODAC, also what I am planning, what LED did you use in the ODAC the same as the o2? I notice the panel is nicely printed, where did you get it can I ask?
The whole idea behind the O2 was to build an amp that was as perfect and transparent with the least amount of parts and cost and work with 98% of the headphones out there. It has opened many eyes, pissed off some, and helped keep the business lean towards the open and honest side.....
Some of the items mentioned that might measure better may not have been available when the designer went thru the process.
If your transducers in your head cant be improved, that's your EARS, then using parts that spec better wont really matter a hill of beans, but there isn't anything wrong in using them etc... it cant hurt, but may cost more.
Having a car be able to go faster isn't a real great comparison to the finite capabilities of the human ear.....but I like fast cars but would rather have one that had a great suspension etc..
The O2 for the cost (some folks hate that comment) performs very well and competes with many other higher cost alternatives.
Its not fancy and its not really the most durable construction.....if you want billet aluminum knobs and a chassis that weighs a few pounds then this isn't the item for you....but I guess you could put an O2 in a BIG aluminum case with a few bricks and if you don't tell anyone I wonder if they would know....
All the best
Alex
Its so simple there isn't really anything to go wrong. The parts that will fail first are either the cheap filter capacitors that are only rated for 2000 hours, or the volume pot will go noisy. Either will only cost a few $ to replace. High ambient heat will drastically reduce the capacitor lifetime, and dust wont do the volume pot any favors, but lifes too short to worry about it.
As regular readers know, I think the ODAC and especially the O2 have their limitations and are not the end-all. However, for the price (there, I said it) they do perform very well.
