average_joe
- Dec 5, 2008
How do the ES caps compare to no caps with you E5, cmoy, and XM3?
Here is the response from sansafix on forums.sandisk.com:
"The HP output is from a different signal path on the PCB vs the Line out. Line out is slightly better performance in specs because there is no circuitry in the path that is required by the FM antenna which is implemented from the HP cable. So separation and SMR is slightly better."
So it does sound better. Anyone know where I can look at a circuit diagram of the Fuze LO and HP out?
Originally Posted by ClieOS /img/forum/go_quote.gif I am using v1 with E5, cmoy, and XM3. v2 for 3MOVE and T4. |
Originally Posted by ClieOS /img/forum/go_quote.gif Anyway, I finally couldn't stop myself from ordering some really expensive Black Gate NX HiQ for more experiment, especially since Parts Connection is having a spring sale event right now. I don't expect them to come in a week or two (need more connectors as well), but I will keep you guys updated on how Black Gate compare to the Nichicon ES I am using now. Stay tuned. |
Originally Posted by S J /img/forum/go_quote.gif Also seems to be less background noise, though that may be due more to the LOD being at 'max volume' whereas before I used it at 3/4 or so. I haven't had time to sit down and do some comparative listening between the LOD and the headphone out yet, but I'll get around to it sometime soon. |
