Pharmaboy
Okay, I received my S4 8-wire today, and the first question which comes to mind is whether cables also need to be subjected to "burn-in" processes like most other Audio components. I ordinarily use all my cables as needed, and do not subject any to deliberate burn-in processes, even though I put most other components I have got through those processes. Under such circumstances, the only burn-in which occurs with my cables do so by default through normal use, so the ones I habitually use tend to get all the "burn-in" I ever do, whereas those I do not habitually use simply lie fallow, so to speak, and can do so for years. There are cables I've had for 4-5 years which have only seen less than an hour of use, if that, not because I did not like them, but because I was in the habit of using other cables in the arsenal for setting cans, and "turn" of the neglected cables to be used never seem to come...
It strikes me now that I could be doing something wrong. For one thing, if cables do require some burn-in to eventually sound their best, then it means that only the ones in my collection that get frequent play time have the opportunity to aspire to sound their best...
So am I doing something wrong by not putting my cables through formal "burn-in" processes? I want to know what the best cable "burn-in" best practices are, if there are any such processes. Any helpful thoughts would be appreciated.
I'm not sure "right" or "wrong" apply here. This is more a "whatever makes you most comfortable & confident" thing.
I burn-in everything audio, right down to NOS tubes and cables. With headphones & electronics I burn-in no less than 150 hrs, and in certain cases (DACs reputed to require especially long burn-in) I might go 2-3X that.
But with small stuff like tubes & cables I do burn-in more casually & for less time. I just burned in my new ForzaAudioWorks HCP Noir cable (my 2nd of these terrific copper cables I'll definitely compare to the Drausk when that arrives). Anyway, I just set it up on my side-system (headphone only) for ~4-5 days, 8-10 hrs/day. I figure it's @50 hrs burned-in now. I think that's more that enough to settle down those copper electrons and get me close to the final sound of the cable.
There's nothing especially scientific about this--but it is empiric, based on my burn-ins of past cable purchases where I heard small but noticeable changes from the cable when brand cold/new vs burned in for 50+ hrs.
