Thanks, gonna ask Trevor than, i'm no expert but would think it sound better because of double internal wiring = more control of frequencies or such.
Hope it doesn't weight a ton and wouldn't cost almost double for like 4 feet
I'm no cable maker, but laws of physics state less voltage loss over large gauges, which probably is the reason for a better sound.
In audio terms you can expect a more full bodied sound with more weight to each tone.
Bass authority is also improved.
It weighs a lot for a cable, after all there is quite some metal used here.
And it also costs slightly more than twice of a regular Silvergarde S4 (it uses exactly twice the material and has a more complex manufacturing process, so to me the pricing makes sense)
Are you also using the 8-wire with Solitaire?
I will, hopefully.
Truth be told, Trevor has still to ship my Silvergarde S4 8-wire. I'm waiting extraordinarily long by now.
You know trevor, he gives a lot of due dates that he doesn't manage to Hold, and my current due date is that he will drop them off on monday.
I ordered it with mini XLR for my Empyrean and on top ordered matching S4 8-wire adapters to the Solitaire P.
However Trevor never did cables for the Solitaire P before and doesn't own the headphone himself. Given that the connector is far recessed into the earcup it might not fit in the end, hopefully it still does.
