Normalising Lossless Files/Apple Lossless?
Jun 2, 2008 at 9:53 AM Post #16 of 17
bowraboy
Originally Posted by carlosgp /img/forum/go_quote.gif
The new iVolume is fast and works very well, but it has some usability issues that need to be solved. For example, the program checks all the files every time you press the "start" button, searching if they are leveled already. If you have a big collection, this is a pain in the ass. As a workaround, you can create a "ignore" list for the leveled files, but you need to add them manually to the said list.
You can select the tracks in iVolume and "adjust selected" from menu bar.
Jun 2, 2008 at 11:35 AM Post #17 of 17
carlosgp
Yes, but this is uncomfortable if your database has about 3000 albums. First you would have to find the desired albums, select them, etc. Nothing "impossible", of course, but for me it's easier the ignore list method. It could be better if you could use iTunes playlists too.
