ddanois
Did u find the Heimdall 2 with the Utopia bright? thin?
I actually do find it to be bright now that I have had the DHC Prion for a while. Still a great cable though.
H2 is a tad (but not overly) bright but this is a great upgrade cable over stock. Still preferring my Silver Spore 4 and Silver Complement 4 and imho if budget can be stretched, DHC cables are great.
The big downside of the Heimdall2 headphone cables are it's build quality. For $800 the last thing you'll expect is getting 32AWG cables for your money (even my item cables are much thicker)...not that it matter in terms of SQ but I always have a feeling that the cable will snap unless I treat it like a baby...something you might want to keep in mind before buying
Personally, I prefer the Nordost XLR termination + adaptors. It allows me to use one cable in different configurations. I have never had a cable failure. The cable is light weight so it doesn't drag your head down. I like that the Heimdall2 does not color the sound or change the characteristics of the headphones. Music sounds more open and more alive with the Heimdall2.
Major shame on Nordost...to think that when you bought an expensive cable, the last thing you'll expect to see is that it comes in a chicken wire size cable, and the need to constantly be worried about your cable snapping off or be damaged by the slightest mishandling.
Tho Nordost provided 2 adapters (1/4" and 3.5mm TRS) for it's default XLR termination, they are bulky and uncomfortable to use. Not having the option to order them with different termination is also a pain
OTOH, the cable matches pretty well with my Utopia thus far. How well? I won't know until all my other cables (from DHC, Norne, Wywires & Plus Sound) arrives and I get to compare them side by side. Unless this Nordost stands out against the competition, it looks like this will be quick good bye as I'll move on to other more robust and better sounding options.
Originally Posted by krumley7882 /img/forum/go_quote.gif
Hi- Wondered if you had any new insights or thoughts on how this cable compares? Kindly
The stress relief material on the right is red....the other is not
