'noodle' dac (ebay special)
Oct 31, 2008 at 1:22 PM Post #121 of 180
mwofsi
Again, I may be way off base here but I would be inclined to use smaller caps between the regs and after, say 100uF. It's my belief that the size of the caps influences the power supplies ability to respond to changes in demand.
I know for sure that it is a complicated subject, power supplies, their recipient and even the distance between the two are all intimately related. It's possible that I'm wrong about my conclusions here.
I hope that I'm being of help.
Oct 31, 2008 at 2:13 PM Post #122 of 180
00940
I wouldn't bother with a second reg. You're dropping a lot of voltage but not a lot of current. If anything you could try a crc filter. Something like that: 4700uF- 33r/1w-4700uF-lm7805-470uF. If the regulator is kept close to the caps, there is no real need for film caps there; those belong to the local decoupling.
Oct 31, 2008 at 3:28 PM Post #124 of 180
00940
The crc just consists into dropping a big resistor in serie before the reg. Let's say you have a current draw of 100ma. If you put 33r in serie, V=R*I, so you drop 3.3V. If you put 50R, you'll drop 5V.
Now, that reduces the power dissipated by the reg from 12V*0.1A= 1.2W to 7V*0.1A= 0.7W. For a 50R resistor, the power dissipated by the resistor itself will be : 50*0.1*0.1=0.5W. Thus you have to pick at least a 1W resistor.
The name crc means: cap-resistor-cap.
Nov 1, 2008 at 6:20 PM Post #125 of 180
gurusan
thanks for all that.
Ok so I actually found a regulated DC wallwart in my closet that puts out about 12.8V DC, I think this will make my PSU smaller and more simple.
Redesigned my little PSU circuit for the DAC as follows...
Nov 1, 2008 at 9:37 PM Post #130 of 180
linuxworks
Member of the Trade: Sercona Audio
I have that PS (of course) and it DOES seem to work pretty well.
it just surprised me to see that brute force amount at the end.
just make sure you get 105C (temp) caps and a good safety rating of volts over what you are putting out.
personally, just my guess - the 470 is probably more than you'd need anyway. otoh, the chinese manuf. usually do NOT put stuff on boards that isn't needed. they are often NOT putting things on boards, so any board part probably has a really good reason for being there else it would have been cost-reduced OFF the board
Nov 4, 2008 at 7:51 PM Post #131 of 180
gurusan
So I got my little PSU setup and the DAC works again! Now running it via optical from PC to DAC to my Starving student and it sounds VERY good through my HD 580s!
I am using a 12V DC linear regulated wallwart I had hanging around...So my little PSU has ~12V in, drops a few volts across a 1W 33R resistor...gets filtered a bit through a 4700uF Rubycon YK cap from the old PSU...then gets regulated to 5V with the l7805 from the old psu...then gets some final treatment with a 1500uF Sanyo WG I had from my old XFI project.
Here are some pics of it, to compare size with the old psu as well.
Nov 5, 2008 at 9:17 PM Post #132 of 180
gurusan
Ok with no load (psu circuit only, DAC not hooked up), my output is 5.00V according to my DMM....but with the DAC on and converting an SPDIF optical signal it uses between 131-132mA....and my voltage is jumping between 5.05V-5.08V.
How can I fix this? The resistor is dropping about 4.36V from the 12.7V source so the L7805 is only dropping about 3.34V... are the film caps in the original dac PSU needed to keep the vReg stable?
Also the 1W 33R resistor is quite hot...but according to my calcs it should only be putting out about .57W of heat? Is it normal for these to retain heat as there's not much surface area to dissipate it.
Nov 6, 2008 at 7:07 AM Post #133 of 180
adamus
half a watt, over small package like a resistor will put out some heat. as long as its within spec it should be fine.
Nov 6, 2008 at 2:50 PM Post #135 of 180
Nemo de Monet
Originally Posted by gurusan /img/forum/go_quote.gif
Ok thanks...any thoughts on the .05-.07V overvolting on the 5V output?
I wouldn't worry about it; that's, what, a 1-1.4% variance? That's pretty good, given the basic design you're using. If you check the L7805 datasheet, you'll see it's "within spec" between 4.8 and 5.2 VDC. The L7800 family of regulators have a lot of nice features (thermal and short-circuit protection, for example) but "high precision" isn't one of them.
