Schmidter
- Mar 17, 2016
When I split my headsets audio and mic to my Audio-GD R2R 11 and then the mic output on the on-board audio in my PC, I get noise in my headset. I tried with two splitter cables, same thing. Would an external USB dac, where I can connect my headphone output to, maybe fix this issue? Since my theory is that it is from the noise inside the PC? Thanks in advance for any help I can get, and have a great day!
Edit: When I connect to only the on-board, there is no noise. So perhaps not the noise inside the case? I don't know much about these things, hope someone can enlighten and help me out.
Edit2: I have a splitterbox, if I connect to that instead, a box that can split connections, I also get noise. Even though I'm connected to only the motherboard on-board. So it happens always when I connect through another device, while both mic and headphone is active. If I use only headphone, every option gives no noise by itself. It only happens when mic is also attached. But as I stated, if I connect directly to my PC only, there is no noise. Only when the audio goes through something else, does it introduce noise.
