Noise isolating vs noise canceling
post-10542702
Thread Starter
Post #1 of 4
inter1097
Hi, I will be on a road trip in a couple months  and  I will mainly be listening to scanner/cb audio and want to be able to hear communications as best as possible over the car stereo Some am/fm but over all just a radio hobbiest.   I am speaking over-ear only, and nothing super expensive. ( $80-ish  tops)
Thanks for  any help you can give!
post-10542728
Post #2 of 4
GREQ
Frankfurt am Main
Frankfurt am Main
Website
app.gitbook.com
I wouldn't waste money on a noise cancelling headphone at that price-range.
I'd get a decent set of IEMs, and maybe buy memory foam tips (Comply is a brand that makes these).
As memory foam tips act like regular ear-plugs and will block out most sound compared to the standard silicone tips that block out less sound.
However, silicone tips last much longer, and are much cheaper to replace, and even with silicone tips most IEMs will block out more sound than many over-ear headphones so you may not need to upgrade the tips at all.
post-10542764
Post #3 of 4
SteveHiFi
Member of the Trade: HiFi Headphones
I'd say full-size, closed back, and as cheap as possible!
AM/CB will give you a headache on anything accurate before you get to the end of your street! Try the Sennheiser HD201 for under $30, they'll be fine unless you sit on them - so don't be a breaker breaker!
post-10547244
Post #4 of 4
zunehdrocks
Donscorpio dolphin
logitech ue6000
for iems
xiaomi piston 2
moxpad x3
ostry kc06 (a bit to mellow on bass impact to some)
