hoader
- Aug 3, 2005
Hi there:
I'm new to this forum and my questions may be odd compaired to the main stream. I have a 30 year old tractor that I use to do work for the neighboring farmers. It does have a full cab but is still loud. I was hoping for something I can use to reduce this noise. I would like to listen to music but not at the volume necessary to drown out the tractors drone. The ideal situation is something that will reduce the noise comming from in front of the operator seat but still hear the equipment, especially PTO operated equipment; it is important to hear a problem that may not be obvious from the tractor seat.
I know the tecnology exists to do this but I have no idea what is available. An article I read claims a microphone is used to listen to the ambiant noise. If I had 2 microphones, one could be directed forward to reduce the engine noise and the other directed behind the cab could boost the equipment noise. This is a guess but, the tractor at operating speed and under load is close to 100 dB in the seat. The noises I have to hear are: the bang of the plows tripping, odd or new noises the hay bailer, cutting machines may make. The mowers are the quietiest but I have no idea how loud they are independantly since the tractor powers them.
The environment inside the cab can vibrate and shake, be hot, cold, damp, extreamly dusty, and basicly harsh. The cab has pervisions for a radio in the roof. It has space for a pair of 5.5" round speakers. I have a welder that says larger speakers will fit.
I need suggestions as to what is my best setup and what is the most affordable and what is in between! I hope you enjoy thinking about how I can combat this noise problem. Thanks hoader
