fjhuerta
I gave Jude an Orpheus and all I got was this lousy title.
- Jun 30, 2001
I'm thinking about getting a much stiffer power supply: 4A at 6VDC. Then, roll tubes and op amps. Can't hurt.
Can anyone post a shot of the pcb? thanks
in this video: https://youtu.be/9RhD-NO0n-4?t=143
you can see some close up shots of the PCB.
Thanks a bunch. I guess the google ones were right then =)
i will post when i have mine with linear PSU, swapped opamps (probably burson v5i), russian tubes
I have just ordered a NS-08E for tube rolling fun, but also a NS-01E (the small one with a single tube) to use at work.
With its 5x5 cm it can easily stand on top of an ODAC, and with a minijack jumper cable it will make a very compact solution. And hopefully a more pleasant listening experience than O2+ODAC, which I have found a bit too fatiguing with Ultrasone PRO900.
It will be interesting to compare NS-08E and NS-01E against each other.
Nobsound claims that NS-01E is their best headamp, but it might just be a marketing trick or because its stock tube is better than the ones on NS-08E.
Changing the tube on NS-01E is probably also a good idea, although it will require some soldering. Does anybody know which one it is? An ECC70/6021 perhaps?
EDIT:
How long does it generally take for these E180F/6688/6Ж9П tubes to burn-in enough to reveal their true sound signature when paired with the NS-08E?
I went a bit overboard and ordered 7 different sets of NOS tubes (Tesla, Philips, Dario Miniwatt, 60's Valvo, 80's Mullard, 70's 6Ж9П-Е and 80's 6Ж9П-Е). I am eager to try them out, but in order to make a fair comparison I should probably start out by doing some kind of systematic burn-in for all of them.
I am thinking about 24 hours of music at a reasonable volume level for each tube pair. Would that be enough to give them a fair amount of burn-in?
