svyr
- Jun 8, 2009
ps appreciate d marc0 organizing and noble sending a tour unit
I'd really like to try the spiral dots but not sure which size is a fit for me. too bad they dont sell a mixed size pack. i currently use the blue inner tips i got with the iems. medium?
also the red inside tips are a decent fit, what size would they be in the spiral dots?
Biggest tips are equal to L size of Spiral dots. I will take some pictures tomorrow in day light as comparison. I have SD tips rigt now and I can recommend them.They fit well and comfortably.
mmm, so I'm really impressed with the tuning. Especially given they incorporate the feedback provided for N4 and are better than N4 at least for my liking
Sound-wise - Very very impressive u shapedish iem. I wouldn't call them neutral but they are balanced in the sense that there are no usual offensive mid bass, or 5 or 7 or 8-10k peaks. I usually look for a sweet enough but still crisp and detailed mids, prominent but crisp bass and sub-bass, no mid bass bloat and extended but not sharp highs and that's what it is... so to me it is balanced.
Nicely accentuated /detailed mids(with what I fell is the right amount of warmth, perhaps very )slightly to lush on some tracks. The detail retrieval is on par with Altone a350 and H300 mids if not better. However, noble mids are probably a bit sweeter if not a bit too much at times for some tracks (or they just highlight it on tracks that already have it in it. e.g. this)
With the highs being tuned to the point of just right for me (a bit less, it'd sound dull, a bit more and they'll start sizzling a bit). If you have a bit hearing and HF hearing loss you might find them a touch
dim but for those of us that are sensitive to sharp treble peaks - they're just right.
The balance/gradient between sub-bass and bass and mid bass is almost perfect (sub>bass>mid bass) and the feeling of decay and speed and impact are all at a level of a well tuned hybrid IEMs dynamic driver to my liking. No bloat anywhere and very easy to appreciate bass texture for anything from piano to drums to double bass to bass guitar for NS (I usually give these 4 tracks a spin to get an idea oh well things are in this department this1, this2, this3, this4
UNEQed (!!) I like it more than (T-Peos) h300 \ a350 EQed. NS puts a smile on my face whether it's acoustic, rock, pop, metal, dubstep or violin or piano+ orchestra :O. (with A350 EQed you can notice the bass decay and amount is a bit out of shape (too much of both) and the mids and highs are not quite as refined)
The bass(uneqed) with proper seal makes me smile even after h300 /a350.
The only negatives would probably be
a) Overally NS is probably a bit forward and sweetsounding with not the biggest soundstage at times. It might be a bit fatiguing for the same reason (nothing's stopping me from turning it down but enjoying it too much loud)
b) too expensive for 2ba (?) (that said I've heard much worse and outright poorly tuned 3-4-6-8 driver IEMs so perhaps there's no issue here)
c) horribly uncomfortable for me (unnecessarily large). I can only wear then down (as per one of the pics) and only get a seal with comply tips . (they should include some comply tips and a cable with a longer strain relief memory wire and make a smaller universal mold)
d) build quality wise I'm not quite sure how to stack it against bullet shaped titanium body IEMs =)
e) dislike the cable (like the small plug, dislike the memory wire). no included shirt clip :/?
long story short, I'd probably consider getting a custom of these if I had a spare kidney to sell. Hats off to 'Dr John' , would definitely like to hear K10 at some point to see what the flagship is like to compare
I use the blue inner tips that came with the savants, are those Medium or MediumLarge (ML) or Large equivalent of the spirals? I noticed they have a ML version too which only makes the entire process harder to decide. Really wish they sold a M/ML/L kit so people could figure it out without buying all 3.
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
My initial impressions are positive.
As a ashamed bass head, I feel I probably couldn't own these exclusively as my only pair of iems, however they have a magical tuning. I find them addictive.
There is something in the I dunno, 3.5k-4k area that can make things get a bit eye twitchy on some of my heavier music, when i EQ this down slightly it helps on such tracks (Think Pantera etc).
However if I leave this eq in place, they loose their magic, so I decided to just leave them without EQ and steer clear of such tunes haha.
Listening to The Corrs Unplugged, Cat Stevens, Nora, Yvette Young, Gipsy Kings, Alice in Chains unplugged, David Gray, heck even Ed Sheeran, these are just so so enjoyable.
I will not get much of a chance to listen to these over the next 2 days (Taking the wifey to Melbourne for dinner and to see the Lion King Stage Show for our Anniversary, then will be on daddy day care duties the following day, so hearing is a must haha).
But I will put some serious time down and get some notes together.
Really liking them as I say, but if I were to buy it would be a complimentary purchase, not my staple.
Thanks for sharing mate.
Was the Savant driven straight from the Alien? I was wondering if you've tried other sources because from what I've heard the Alien is quite forward sounding which results to much clarity and detail. But definitely the Savant has some emphasis in the upper mids.
