Noble Audio - the Wizard returns!
Nov 3, 2019 at 8:03 AM Post #31,382 of 36,038
Nov 4, 2019 at 7:22 PM Post #31,384 of 36,038
To all who recommended the Azla SednaEarFit tips, thanks! These tips are the best, I have tried.
Nov 4, 2019 at 8:08 PM Post #31,386 of 36,038
Eager to try to Azla tips, but want to get the right size. How do they compare, size wise, to the Spiral Dots? In case if anyone has used both, it would be helpful advise. Thanks.
Azlas run a bit large. I’d recommend sizing down.
Nov 4, 2019 at 8:12 PM Post #31,387 of 36,038
I have not used spiral dots, but they do run 1 size bigger than Final type e. I wear a S in Final type e, and the SS from Azla, and they are identical in width. They have the measurements in mm, on the Azla website.
Nov 4, 2019 at 8:13 PM Post #31,388 of 36,038
Nov 4, 2019 at 8:18 PM Post #31,389 of 36,038
Thanks all for the inputs. In case anybody wants for reference, here are the measurements.
Nov 4, 2019 at 9:43 PM Post #31,391 of 36,038
One other thing to note is that the Spiral Dot is a shorter tip than the Sedna. Could affect how it fits you, depending on your ear anatomy.
Nov 4, 2019 at 10:22 PM Post #31,392 of 36,038
Thanks. Glad I checked as I'm a L size spiral dot and looks like they are the same at that size.
Nov 5, 2019 at 3:11 AM Post #31,393 of 36,038
Nov 6, 2019 at 2:13 AM Post #31,395 of 36,038
I have both spiral and Azela the spirals are alitte on the shorter side compared to the azela so if you have iems that are a bit long when it comes to tips on and they end up sticking out then the azelas would be better as they seem to be made for long iems its kinda like the spin fit but with more room for the sound to travel out i would say. comfort wise honestly azel is hands down one of the best i used to use the finals but ever since i found the azelas i basically switched all my tips to them
