Noble Audio - the Wizard returns!
2065 2066 2067 2068 2069 2070 2071 2072 2073 2074
2076 2077 2078 2079 2080 2081
  1. FullCircle
    Driver tech has several names
    Magnetostat
    Another is acts
    A few other names are floating around
    It is basically a dynamic + flat all on the same axis
    Noble Audio Stay updated on Noble Audio at their sponsor page on Head-Fi.
    https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
    Deezel177 likes this.
  2. FullCircle
    That is the standard face plate.
    Basically a mix of brown, copper, & silver
  3. FullCircle
    Kind of a dalmatian look on the body and face plate
    hotdog108, ayang02 and Deezel177 like this.
  4. iBo0m
    Yeah, but "useable" doesn't really say much. I was unable to find any info (user's experiences) on this cable as well as your Aureole Cable on the web. In case you are able to do a picture of those next to each other, it might say a lot (I know the standard cable and Khan cable, so I'm able to imagine the difference).
  5. mvvRAZ
    I'm receiving my Khan next week and I'll be able to send you some photos.
    iBo0m likes this.
  6. FullCircle
    Hq has cables, I don't so I am little help to u with photos
    Aureole isn't my cable, that cable is built by Wagnus you may find more information about that cable on his website.
  7. EndGameSearch
    I'm primarily a headphone guy but decided to pick up an IEM while in NYC yesterday. I checked Audio46' inventory on-line, saw the Kahn was in stock, read two reviews, and bought a pair on a whim in between meetings. I normally spend more time researching before making gear purchases, but it looks like I lucked out and ended up with an amazing IEM. That said, I have a couple rookie questions that are likely hidden within this mega thread.
    1. Tips clearly make a huge difference on the signature with Kahn. I typically prefer silicone (SpinFit) but find the stock foam tips work well. Yes, it's a very subjective topic, but before I start ordering various silicone tips to mimic the signature I'm getting with foam I thought I'd ask for a few opinions to point me in the right direction. I've tried the Symbion hybrid tips which just don't work for my ears, nor do multi flange tips. My ear canal is very shallow.
    2. I found the comments a few pages back regarding cables interesting. I typically upgrade cables for aesthetic and ergonomic reasons, but appreciate the subtle sonic changes that follow. If the signature/presentation is actually altered or not, some times for me it's worth the spend knowing I've done everything possible to get the very best out of the HP/IEM. Psychological or not, if I think it sounds better, then it sounds better. Has anyone tried the Effect Audio Cleopatra Octa? That seems like it would be a good fit.
    3. On another topic that is debatable and potentially psychological, what is the general view regarding burn-in? What should I expect? I'm generally of the mindset that it surely won't hurt, so I've had them burning for the past 12 hours and will let it go a few days.
    4. Finally, one more subjective topic. I'd appreciate any suggestions on a TOTL dap that pairs well with the Kahn. I only use IEM's when mobile and have a Hugo 2 for hotel use and a dragonfly for flights. All of my music is streamed through Tidal and Qobuz which I store offline on my iPhone XS Max, thus my DAP must support off-line streamed content. I've read that the TOTL A&K DAPs may not be the best pairing for this hybrid (correct me if I'm wrong). I assume the DX220 would be a good fit, but am open to suggestions. I'm more concerned with performance than price.
    Pardon the long post and thanks for any input you provide on the thread or via PM.
    Misson07 likes this.
  8. FullCircle
    Regarding dap
    Reports of artifact with the use of the 220 and ak sp2000
    There is a inline emi filter that is available if such an issue occured.
    I use the AK SP 1000 copper, nothing but grins to report.
  9. EndGameSearch
    Thanks for the response. Assuming an inline emi filter would be in the form of an adapter/dongle, I'd prefer to keep it simple and go with want works and "grin" worthy...
  10. EndGameSearch
    I will add, that to my surprise the new Cobalt Dragonfly has a very strong hiss with Kahn off my iphone, but the older red model is silent. I won't leap to the conclusion that the issue is 100% tied to Cobalt since I saw another user pleased with the results a few pages back. I've tried them off my Chord TT2 and Chord m-scaler / DAVE and both are top notch with black backgrounds. I'm listening off a MAC / Roon > UpTone Regen > Hugo 2 right now and it's outstanding as well. I hear a little static every now and then but chalk that up to dirty power or my MAC.
  11. iBo0m
    Thanks! However, I know the Khan cable very well. The new 8-core and Aureole are sort of a mystery to me. Basically, the only pictures and some info I've found about them is on the Noble Audio websites.
  12. EndGameSearch
    Does anyone know the diameter of Kahn's tip? I want to make sure I'm ordering the correct tip size. Thanks in advance...
    mvvRAZ likes this.
  13. mvvRAZ
    Interested +1
  14. Watagump
    My Spinfits are 4 mm and they fit perfectly.
    EndGameSearch likes this.
  15. EndGameSearch
    Great, thank you. Those are the tips I was planning to order as well.
