Noble Audio - the Wizard returns!
  1. FullCircle
    Built with love
    Noble Audio Stay updated on Noble Audio at their sponsor page on Head-Fi.
    https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
  2. BananaOoyoo
    How’s the fit on the Khan (compared to the other Noble universal models)?
    Apparently a couple people here in Korea got a chance to try them briefly (I think when Noble Audio was getting their new distributor set up, they stopped by a store here)... really bummed I wasn’t there!
  3. Watagump
    I will let you know tomorrow.
    BananaOoyoo likes this.
  4. WCDchee
    So I got to try some new hyped up flagships like the Sony IER-Z1R, the CA Solaris, Jomo trinity (brass).
    The Khan is personally an easy pick tonally and technically.
  5. proedros
    solaris is like 1500$ , so not sure if it's considered a flagship
    however, i would love to see @flinkenick review Khan , him having heard true flagships like Zeus XR / SE5 / A18 etc
  6. BananaOoyoo
    IMO the term “flagship” should be a descriptor of performance, not price.
    That is, while I have not yet heard any of the three (Z1R, Solaris, Trinity), if, hypothetically, the Solaris is “better” than Trinity, then it’s more deserving of the flagship title.
    justrest likes this.
  7. Painterspal
    I’d appreciate some help from fellow Noble enthusiasts. I have a pair of universal Kaiser Encores and have always founds it hard to get a good fit with aftermarket tips. I can get Complys to work but I’ve had no luck with all the silicone tips I’ve tried, and believe me I’ve tried a lot! Even hybrid tips like the mandarins don’t work for me. The only silicone tips that work are Noble’s own medium sized red silicones. They sound fantastic - far better than the Complys - and more comfortable too. Where can I buy more or is there an aftermarket alternative that’s close? I’ve spent a lot of cash trying different makes without success so would really appreciate a steer...
  8. fiascogarcia
    Wouldn't they be the same as the ones Noble sells in the accessory section of their website?
    Note: I just looked at their website, and you're probably looking for more of the specific type and size, rather than buying a whole set of their multipack just to get one pair that you like. Maybe contact them directly?
  9. Watagump
    Don't feed the trolls, it makes them hungry for more.
    proedros likes this.
  10. canadan
    Hey all,
    My cable on my K10’s has started to split by the 2 pin connector. I’ve looked at replacing it with another noble cable but the shipping is crazy to send the cable to the UK! And also it seems that the UK version of the Noble site is down for the last few days anyhow.
    Anyone know of anywhere that does a similar cable and will post to the UK for a reasonable price?
  11. Painterspal
    Thanks. When I looked earlier their site seemed to be down. I also didn’t consider this option as I’m based in the UK so I figured the postage would be pretty high. I only want the medium size so I’ll contact them and check it out.
  12. Frankie D
    I would suggest not comparing price among different companies for the purposes of what is their flagship or best product. While I have not yet heard the Solaris, it is billed by Campfire as their new Flagship. Campfire also tends to be of a lower cost than most of the other IEM manufacturers that try to produce a TOTL in ear monitor. I hope to hear it at Canjam. Tks.
  13. RPB65
    The website is ok as of my post here. However, the £30 shipping cost is not! :frowning2:
  14. Watagump
    Arggggggggggg, just heard a truck outside, ran to my window and its a damn trash truck.
    krismusic, Rowethren and BananaOoyoo like this.
  15. bimbim
    What you want is JVC spiral dot tips medium/large size
