Noble Audio - the Wizard returns!
  1. krismusic Contributor
    Just that as it is it is still a very desirable artifact. To get back on topic, imagine how many new Noble customs you could buy for one Banksy!!
  2. Watagump
    Probably could buy Noble. I would keep John and the staff though.
    krismusic likes this.
  3. Watagump
    Where did the drive by critic go? I had a feeling it was going to go that way.
  4. Watagump
    Well, dammit, I got my K10's back today after being on the road again for a while. That is suppose to make a good day even better, BUT, I head out for my bike ride, I get about 10 minutes in and realize the sound just isnt right. The balance is off, more sound in my left ear, normally this is an issue of a bore being clogged. But since I didnt even have them for over a month, how could that be it? Well, that was it, I didnt even have my glasses on so it was hard to see but I found some what was probably ear wax in the smallest bore.
    I stopped in a place where there just so happened to be a used toothpick in the crack of the sidewalk, yup that will work. :fingers_crossed:I stick it in, notice the hole is open again and audio bliss was restored. 30 minutes later, I run over a sheet metal screw and have to swap my tube out. Same area I ran over the exact type of screw months ago, anyhow, made it home, cleaned the bores again with a better sharper end, some day I might just get a jodivac.
  5. FullCircle
    I had to use a 100 Taiwan dollar bill and a wad of fresh bubble gum to fix a flat once
    I was out in the middle of nowhere, luckily the patch worked well enough to get me out of the mountains and back to civilization.
    Noble Audio Stay updated on Noble Audio at their sponsor page on Head-Fi.
    https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
    ayang02 and krismusic like this.
  6. Watagump
    I carry spare tubes, a pump and a set of wedges to remove the tire. I think it takes as long to pump the tube up as it does to swap it.
  7. Watagump
    fiascogarcia likes this.
  8. Redcarmoose
    The fastest I ever went downhill was 46mph. What’s startling was the difference the wind noise is from the spokes from 40mph to 46mph?
    In a way I reference my Encore and old Colnago the same way.....simply...art.
  9. Redcarmoose
    I have tried the IT04, what your saying is you would like a motorcycle with a 454 Chevy engine. It’s simply not physically possible. The Encore does more because it has more. One trick about fitting is to understand what changes you have to make to get your Encore to fit right. If your like me the nozzle was ever so slightly too short. I found a set of SpinFit tips which were exceptionaly long. Then I took an old IEM tip and cut the inner rubber shaft into a small O ring. It’s a super small ring that I put on before placing the SpinFit tip on. Now I have increased the nozzle area creating a perfect fit. It’s been a couple months and all is well.
    I actually have some semi-custom chi-fi IEMs like the IT04 and yes, they are comfortable because they are small and fit inside against the ear, still there is no comparison when it gets to overall sound.
    Saraguie likes this.
  10. krismusic Contributor
    I was going to buy a Jodivac. I think it was John warned me off. Danger of dislodging the dampers.
    Watagump likes this.
  11. petetheroadie
    What do folks use to clean their CIEMS?
  12. Watagump
    I never considered the dampers, makes sense though.
  13. Watagump
    I use a safety pin type of thing, also the cleaning tool that comes with it, the brush etc and I will wipe the outside with a rag.
  14. proedros
    is this about customs or universal shells (or bth) ?
    do we have any more on the matter ? has this happened to anyone ? really curious about it as many people here own jodivac
  15. Saraguie
    WHERE’s the popcorn imoji when u need it ??
